jengelh Aber dscli kann SRV auch selber suchen, da braucht's kein Script für.
*hüstel* grad entdeckt das du das ja auch erst vor kurzem eingebaut hast.
Und das nur weil ich nun endlich mal Changelogs im system gefunden habe *g* weil apt-get changelog gromox
sowie rpm -q --changelog gromox
ja nicht wirklich aussagekräftig oder gar leer ist.
debian
cb@grom-deb ~ % zcat /usr/share/doc/gromox/changelog.gz |sed -e '1,/^1/!d'
1.33.24
Enhancements:
* The gromox-dscli command-line utility now performs DNS SRV lookups.
Fixes:
* dscli: in absence of SRV records, fall back to autodiscover.<domain>,
not <domain>.
* ldap_adaptor: the per-org LDAP base was erroneously used with the
default LDAP.
* midb: resolve a startup crash in conjunction with musl libc.
1.33 (2022-10-20)
cb@grom-deb ~ %
opensuse
gromi:~ # less /usr/share/doc/packages/gromox/changelog.rst |sed '1,/^1/!d'
1.31 (2022-08-30)
Enhancements:
* kdb2mt: add a size column to the disambiguation table
* exmdb_provider: added the "exmdb_search_yield" and "exmdb_search_nice" config
directives
* exmdb_provider: add a vacuum RPC (and expose via gromox-mbop(8gx))
* emsmdb: implement cached mode cross-store move support
Fixes:
* kdb2mt: filter unwanted properties on writeout rather than readout
(rerecognize special folders)
* oxcical: recurring appointments now have their summary ("effective ... from
02:00 to 02:15") displayed without uncanny time shift
* oxcical: oxcical_export_timezone had missed emitting BYMONTHDAY subvalues
* oxcical: avoid month wraparound with recurring events in December
* dscli: fix nullptr deref when -x option is used
* nsp: show DT_DISTLIST icon for mlists
* oxcical: set PidLidRecurring and PidLidRecurrenceType tags when importing
recurring events
* Check for iconv capabilities on startup so that we do not start on containers
with too few libc components installed
* zcore: avoid UAF when unpacking SMIME messages
* imap: do not emit body-QP in () groups when encoded-word-QP is expected
* imap, pop3: avoid hanging clients if response buffer is full
Changes:
* The default value for "exmdb_search_pacing" was changed to 250 to improve
interactivity with OL during online search.
* oxvcard: disable pedantic behavior on import
1.28 (2022-07-25)
