here is the output. I have choosen 1 to all solution propositions.
zypper repos -d |sed 's#/.*@#/#g'
# | Alias | Name | Enabled | GPG Check | Refresh | Priority | Type | URI | Service
1 | base | base | Yes | (r ) Yes | Yes | 99 | rpm-md | http://do wnload.opensuse.org/distribution/leap/15.3/repo/oss |
2 | debug | debug | Yes | (r ) Yes | No | 99 | rpm-md | http://do wnload.opensuse.org/debug/distribution/leap/15.3/repo/oss |
3 | debug-update | debug-update | Yes | (r ) Yes | No | 99 | rpm-md | http://do wnload.opensuse.org/debug/update/leap/15.3/oss |
4 | grommunio | grommunio | Yes | (r ) Yes | Yes | 99 | rpm-md | https://d ownload.grommunio.com/community/openSUSE_Leap_15.3/?ssl_verify=no |
5 | repo-backports-debug-update | repo-backports-debug-update | Yes | (r ) Yes | No | 99 | rpm-md | http://do wnload.opensuse.org/update/leap/15.3/backports_debug/ |
6 | repo-backports-update | repo-backports-update | Yes | (r ) Yes | Yes | 99 | rpm-md | http://do wnload.opensuse.org/update/leap/15.3/backports/ |
7 | repo-sle-debug-update | repo-sle-debug-update | Yes | (r ) Yes | No | 99 | rpm-md | http://do wnload.opensuse.org/debug/update/leap/15.3/sle/ |
8 | repo-sle-update | repo-sle-update | Yes | (r ) Yes | Yes | 99 | rpm-md | http://do wnload.opensuse.org/update/leap/15.3/sle/ |
9 | update | update | Yes | (r ) Yes | Yes | 99 | rpm-md | http://do wnload.opensuse.org/update/leap/15.3/oss |
XXXXX:~ # zypper --verbose refresh
Verbosity: 2
Initializing Target
Specified repositories:
Checking whether to refresh metadata for base
Retrieving: repomd.xml ................................................................................................[done]
Retrieving: media .....................................................................................................[done]
Repository 'base' is up to date.
Checking whether to refresh metadata for debug
Repository 'debug' is up to date.
Checking whether to refresh metadata for debug-update
Retrieving: media ................................................................................................[not found]
Retrieving: repomd.xml.asc ............................................................................................[done]
Retrieving: repomd.xml.key ............................................................................................[done]
Repository: debug-update
Key Fingerprint: 22C0 7BA5 3417 8CD0 2EFE 22AA B88B 2FD4 3DBD C284
Key Name: openSUSE Project Signing Key <opensuse@opensuse.org>
Key Algorithm: RSA 2048
Key Created: Mon May 5 04:37:40 2014
Key Expires: Thu May 2 04:37:40 2024
Rpm Name: gpg-pubkey-3dbdc284-53674dd4
Retrieving: 92527c45c793ed47792369c0a83e4a749e4fe8dfe73bc2a923f2a5d15a91edd7-primary.xml.gz ..............[done (14.0 KiB/s)]
Retrieving repository 'debug-update' metadata .........................................................................[done]
Building repository 'debug-update' cache ..............................................................................[done]
Checking whether to refresh metadata for grommunio
Retrieving: repomd.xml ....................................................................................[done (3.0 KiB/s)]
Repository 'grommunio' is up to date.
Checking whether to refresh metadata for repo-backports-debug-update
Repository: repo-backports-debug-update
Key Fingerprint: 637B 32FF 3D83 F07A 7AE1 C40A 9C21 4D40 6517 6565
Key Name: openSUSE:Backports OBS Project <openSUSE:Backports@build.opensuse.org>
Key Created: Fri Nov 26 09:26:23 2021
Key Expires: Sun Feb 4 09:26:23 2024
Rpm Name: gpg-pubkey-65176565-61a0ee8f
Retrieving: efabd404ce98e7fc7fe7df80808b79455fcefda883e0a6c551960d7d1358a51f-primary.xml.gz .................................................................................................[done]
Retrieving repository 'repo-backports-debug-update' metadata ................................................................................................................................[done]
Building repository 'repo-backports-debug-update' cache .....................................................................................................................................[done]
Checking whether to refresh metadata for repo-backports-update
Retrieving: repomd.xml ......................................................................................................................................................................[done]
Repository 'repo-backports-update' is up to date.
Checking whether to refresh metadata for repo-sle-debug-update
Retrieving: media ......................................................................................................................................................................[not found]
Retrieving: repomd.xml.asc ..................................................................................................................................................................[done]
Retrieving: repomd.xml.key ........................................................................................................................................................[done (972 B/s)]
Repository: repo-sle-debug-update
Key Fingerprint: FEAB 5025 39D8 46DB 2C09 61CA 70AF 9E81 39DB 7C82
Key Name: SuSE Package Signing Key <build@suse.de>
Key Created: Mon Sep 21 04:21:47 2020
Key Expires: Fri Sep 20 04:21:47 2024
Rpm Name: gpg-pubkey-39db7c82-5f68629b
Retrieving: b4f121ad4fe098857e400848e035b29d17b6f3541f2efa7d14bb8b0e39e4b8f4-primary.xml.gz .....................................................................................[done (4.0 MiB/s)]
Retrieving repository 'repo-sle-debug-update' metadata ......................................................................................................................................[done]
Building repository 'repo-sle-debug-update' cache ...........................................................................................................................................[done]
Checking whether to refresh metadata for repo-sle-update
Repository 'repo-sle-update' is up to date.
Checking whether to refresh metadata for update
Repository 'update' is up to date.
All repositories have been refreshed.
XXXX:~ # zypper --verbose update --dry-run
Verbosity: 2
Initializing Target
Loading repository data...
Reading installed packages...
Force resolution: No
Nothing to do.
zypper --verbose dist-upgrade --dry-run
Verbosity: 2
Initializing Target
Warning: You are about to do a distribution upgrade with all enabled repositories. Make sure these repositories are compatible before you continue. See 'man zypper' for more information about this command.
Computing distribution upgrade...
Computing upgrade...
10 Problems:
Problem: problem with the installed dracut-kiwi-lib-9.24.48-lp153.1.1.x86_64
Problem: problem with the installed dracut-kiwi-live-9.24.48-lp153.1.1.x86_64
Problem: problem with the installed dracut-kiwi-oem-dump-9.24.48-lp153.1.1.x86_64
Problem: problem with the installed dracut-kiwi-oem-repart-9.24.48-lp153.1.1.x86_64
Problem: problem with the installed kiwi-systemdeps-bootloaders-9.24.48-lp153.1.1.x86_64
Problem: problem with the installed kiwi-systemdeps-core-9.24.48-lp153.1.1.x86_64
Problem: problem with the installed kiwi-systemdeps-disk-images-9.24.48-lp153.1.1.x86_64
Problem: problem with the installed kiwi-systemdeps-filesystems-9.24.48-lp153.1.1.x86_64
Problem: problem with the installed kiwi-systemdeps-iso-media-9.24.48-lp153.1.1.x86_64
Problem: problem with the installed kiwi-tools-9.24.48-lp153.1.1.x86_64
Solution 1: install dracut-kiwi-lib-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
replacing dracut-kiwi-lib-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
Solution 2: keep obsolete dracut-kiwi-lib-9.24.48-lp153.1.1.x86_64
Choose from above solutions by number or skip, retry or cancel [1/2/s/r/c/d/?] (c): 1
Applying solution 1
Solution 1: install dracut-kiwi-live-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
replacing dracut-kiwi-live-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
Solution 2: keep obsolete dracut-kiwi-live-9.24.48-lp153.1.1.x86_64
Applying solution 1
Solution 1: install dracut-kiwi-oem-dump-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
replacing dracut-kiwi-oem-dump-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
Solution 2: keep obsolete dracut-kiwi-oem-dump-9.24.48-lp153.1.1.x86_64
Applying solution 1
Solution 1: install dracut-kiwi-oem-repart-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
replacing dracut-kiwi-oem-repart-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
Solution 2: keep obsolete dracut-kiwi-oem-repart-9.24.48-lp153.1.1.x86_64
Applying solution 1
Solution 1: install kiwi-systemdeps-bootloaders-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
replacing kiwi-systemdeps-bootloaders-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
Solution 2: keep obsolete kiwi-systemdeps-bootloaders-9.24.48-lp153.1.1.x86_64
Applying solution 1
Solution 1: install kiwi-systemdeps-core-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
replacing kiwi-systemdeps-core-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
Solution 2: keep obsolete kiwi-systemdeps-core-9.24.48-lp153.1.1.x86_64
Applying solution 1
Solution 1: install kiwi-systemdeps-disk-images-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
replacing kiwi-systemdeps-disk-images-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
Solution 2: keep obsolete kiwi-systemdeps-disk-images-9.24.48-lp153.1.1.x86_64
Applying solution 1
Solution 1: install kiwi-systemdeps-filesystems-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
replacing kiwi-systemdeps-filesystems-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
Solution 2: keep obsolete kiwi-systemdeps-filesystems-9.24.48-lp153.1.1.x86_64
Applying solution 1
Solution 1: install kiwi-systemdeps-iso-media-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
replacing kiwi-systemdeps-iso-media-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
Solution 2: keep obsolete kiwi-systemdeps-iso-media-9.24.48-lp153.1.1.x86_64
Applying solution 1
Solution 1: install kiwi-tools-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
replacing kiwi-tools-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
Solution 2: keep obsolete kiwi-tools-9.24.48-lp153.1.1.x86_64
Applying solution 1
Resolving dependencies...
The following 14 packages are going to be downgraded:
dracut-kiwi-lib 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3
dracut-kiwi-live 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3
dracut-kiwi-oem-dump 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3
dracut-kiwi-oem-repart 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3
grommunio-admin-common 6.cb985db-lp153.14.1 -> 6.cb985db-lp153.2.1
grommunio-antispam 3.2-lp153.8.1 -> 3.2-lp153.1.2
grommunio-error-pages 1.0.6.9c50afb-lp153.7.1 -> 1.0.6.9c50afb-lp153.2.1
grommunio-imapsync 2.200-lp153.4.1 -> 2.178-lp153.1.1
kiwi-systemdeps-bootloaders 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3
kiwi-systemdeps-core 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3
kiwi-systemdeps-disk-images 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3
kiwi-systemdeps-filesystems 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3
kiwi-systemdeps-iso-media 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3
kiwi-tools 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3
The following package is going to be reinstalled:
grommunio-release 2022.05.2-lp153.1.1
The following 10 packages are going to change vendor:
dracut-kiwi-lib 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3 obs://build.opensuse.org/Virtualization:Appliances -> SUSE LLC <https://www.suse.com/>
dracut-kiwi-live 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3 obs://build.opensuse.org/Virtualization:Appliances -> SUSE LLC <https://www.suse.com/>
dracut-kiwi-oem-dump 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3 obs://build.opensuse.org/Virtualization:Appliances -> SUSE LLC <https://www.suse.com/>
dracut-kiwi-oem-repart 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3 obs://build.opensuse.org/Virtualization:Appliances -> SUSE LLC <https://www.suse.com/>
kiwi-systemdeps-bootloaders 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3 obs://build.opensuse.org/Virtualization:Appliances -> SUSE LLC <https://www.suse.com/>
kiwi-systemdeps-core 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3 obs://build.opensuse.org/Virtualization:Appliances -> SUSE LLC <https://www.suse.com/>
kiwi-systemdeps-disk-images 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3 obs://build.opensuse.org/Virtualization:Appliances -> SUSE LLC <https://www.suse.com/>
kiwi-systemdeps-filesystems 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3 obs://build.opensuse.org/Virtualization:Appliances -> SUSE LLC <https://www.suse.com/>
kiwi-systemdeps-iso-media 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3 obs://build.opensuse.org/Virtualization:Appliances -> SUSE LLC <https://www.suse.com/>
kiwi-tools 9.24.48-lp153.1.1 -> 9.24.43-150100.3.56.3 obs://build.opensuse.org/Virtualization:Appliances -> SUSE LLC <https://www.suse.com/>
14 packages to downgrade, 1 to reinstall, 10 to change vendor.
Overall download size: 6.9 MiB. Already cached: 0 B. After the operation, 40.6 KiB will be freed.
Continue? [y/n/v/...? shows all options] (y):
committing (dry run)
Checking for file conflicts: (15 skipped) .............................................................................................................................................................................................[done]
Warning: 15 packages had to be excluded from file conflicts check because they are not yet downloaded.
Note: Checking for file conflicts requires not installed packages to be downloaded in advance in
order to access their file lists. See option '--download-in-advance / --dry-run --download-only'
in the zypper manual page for details.
CommitResult (total 15, done 0, error 0, skipped 15, updateMessages 0)
