Den Eintrag mit Autodiscover habe ich auskommentiert, im weiteren wie folgt
ping grommunio.domain.dl -> 192.168.168.101
ping autodiscover.domain.dl -> externe IP, nicht 192.168.168.101
ping -a externe IP -> externe IP
Die folgenden Einträge stimmen alle
/etc/gromox/autodiscover.ini:/var/lib/gromox/user = grommunio.domain.dl
/etc/gromox/autodiscover.ini:/var/lib/gromox/domain = grommunio.domain.dl
/etc/gromox/autodiscover.ini:hostname = grommunio.domain.dl
/etc/gromox/http.cfg:host_id = grommunio.domain.dl
/etc/gromox/mysql_adaptor.cfg:schema_upgrades = host:grommunio.domain.dl
/etc/postfix/main.cf:myhostname = grommunio.domain.dl
Dann
localhost:~ # systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
0 loaded units listed.
localhost:~ #
localhost:~ # df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 4,0M 0 4,0M 0% /dev
tmpfs 3,9G 0 3,9G 0% /dev/shm
tmpfs 1,6G 828K 1,6G 1% /run
tmpfs 4,0M 0 4,0M 0% /sys/fs/cgroup
/dev/sda3 60G 39G 20G 67% /
/dev/sda2 20M 3,0M 18M 15% /boot/efi
/dev/sda3 60G 39G 20G 67% /.snapshots
/dev/sda3 60G 39G 20G 67% /var/lib/gromox
tmpfs 795M 0 795M 0% /run/user/0
localhost:~ #
localhost:~ # journalctl -f
Feb 12 16:05:21 localhost sshd[479]: Connection closed by 127.0.0.1 port 54652
Feb 12 16:05:22 localhost sshd[482]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:22 localhost sshd[482]: Connection closed by 127.0.0.1 port 54664
Feb 12 16:05:23 localhost sshd[485]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:23 localhost sshd[485]: Connection closed by 127.0.0.1 port 54666
Feb 12 16:05:24 localhost sshd[488]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:24 localhost sshd[488]: Connection closed by 127.0.0.1 port 54676
Feb 12 16:05:25 localhost sshd[491]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:25 localhost sshd[491]: Connection closed by 127.0.0.1 port 54678
Feb 12 16:05:26 localhost sshd[494]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:26 localhost sshd[494]: Connection closed by 127.0.0.1 port 54692
Feb 12 16:05:26 localhost uwsgi[1790]: [ERROR] (flask.app) Traceback (most recent call last):
Feb 12 16:05:26 localhost uwsgi[1790]: File "/usr/lib/python3.6/site-packages/flask/app.py", line 1838, in full_dispatch_request
Feb 12 16:05:26 localhost uwsgi[1790]: rv = self.dispatch_request()
Feb 12 16:05:26 localhost uwsgi[1790]: File "/usr/lib/python3.6/site-packages/flask/app.py", line 1824, in dispatch_request
Feb 12 16:05:26 localhost uwsgi[1790]: return self.view_functionsrule.endpoint
Feb 12 16:05:26 localhost uwsgi[1790]: File "./api/core.py", line 179, in wrapper
Feb 12 16:05:26 localhost uwsgi[1790]: return call()
Feb 12 16:05:26 localhost uwsgi[1790]: File "./api/core.py", line 144, in call
Feb 12 16:05:26 localhost uwsgi[1790]: ret = func(args, **kwargs)
Feb 12 16:05:26 localhost uwsgi[1790]: File "./endpoints/service.py", line 32, in getUserSyncPolicy
Feb 12 16:05:26 localhost uwsgi[1790]: user = Users.query.filter(Users.username == username).first()
Feb 12 16:05:26 localhost uwsgi[1790]: File "./orm/init.py", line 32, in get
Feb 12 16:05:26 localhost uwsgi[1790]: mapper = class_mapper(type)
Feb 12 16:05:26 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/base.py", line 451, in class_mapper
Feb 12 16:05:26 localhost uwsgi[1790]: mapper = inspect_mapped_class(class, configure=configure)
Feb 12 16:05:26 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/base.py", line 430, in inspect_mapped_class
Feb 12 16:05:26 localhost uwsgi[1790]: mapper.configure_all()
Feb 12 16:05:26 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/mapper.py", line 1352, in _configure_all
Feb 12 16:05:26 localhost uwsgi[1790]: configure_mappers()
Feb 12 16:05:26 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/mapper.py", line 3295, in configure_mappers
Feb 12 16:05:26 localhost uwsgi[1790]: raise e
Feb 12 16:05:26 localhost uwsgi[1790]: sqlalchemy.exc.InvalidRequestError: One or more mappers failed to initialize - can't proceed with initialization of other mappers. Triggering mapper: 'mapped class Users->users'. Original exception was: When initializing mapper mapped class Users->users, expression 'admin_user_role_relation' failed to locate a name ("name 'admin_user_role_relation' is not defined"). If this is a class name, consider adding this relationship() to the <class 'orm.users.Users'> class after both dependent classes have been defined.
Feb 12 16:05:26 localhost uwsgi[1790]: [WARNING] (flask.app) GET /api/v1/service/syncPolicy/andreas.kaelber@tsu-pe.de? from ::1 -> 500 '{"message":"The server encountered an error while processing the request."}\n'
Feb 12 16:05:27 localhost sshd[595]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:27 localhost sshd[595]: Connection closed by 127.0.0.1 port 51550
Feb 12 16:05:28 localhost sshd[598]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:28 localhost sshd[598]: Connection closed by 127.0.0.1 port 51562
Feb 12 16:05:29 localhost sshd[601]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:29 localhost sshd[601]: Connection closed by 127.0.0.1 port 51576
Feb 12 16:05:30 localhost sshd[604]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:30 localhost sshd[604]: Connection closed by 127.0.0.1 port 51588
Feb 12 16:05:31 localhost sshd[607]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:31 localhost sshd[607]: Connection closed by 127.0.0.1 port 51592
Feb 12 16:05:32 localhost sshd[610]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:32 localhost sshd[610]: Connection closed by 127.0.0.1 port 51598
Feb 12 16:05:33 localhost uwsgi[1790]: [ERROR] (flask.app) Traceback (most recent call last):
Feb 12 16:05:33 localhost uwsgi[1790]: File "/usr/lib/python3.6/site-packages/flask/app.py", line 1838, in full_dispatch_request
Feb 12 16:05:33 localhost uwsgi[1790]: rv = self.dispatch_request()
Feb 12 16:05:33 localhost uwsgi[1790]: File "/usr/lib/python3.6/site-packages/flask/app.py", line 1824, in dispatch_request
Feb 12 16:05:33 localhost uwsgi[1790]: return self.view_functionsrule.endpoint
Feb 12 16:05:33 localhost uwsgi[1790]: File "./api/core.py", line 179, in wrapper
Feb 12 16:05:33 localhost uwsgi[1790]: return call()
Feb 12 16:05:33 localhost uwsgi[1790]: File "./api/core.py", line 144, in call
Feb 12 16:05:33 localhost uwsgi[1790]: ret = func(args, **kwargs)
Feb 12 16:05:33 localhost uwsgi[1790]: File "./endpoints/service.py", line 32, in getUserSyncPolicy
Feb 12 16:05:33 localhost uwsgi[1790]: user = Users.query.filter(Users.username == username).first()
Feb 12 16:05:33 localhost uwsgi[1790]: File "./orm/init.py", line 32, in get
Feb 12 16:05:33 localhost uwsgi[1790]: mapper = class_mapper(type)
Feb 12 16:05:33 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/base.py", line 451, in class_mapper
Feb 12 16:05:33 localhost uwsgi[1790]: mapper = inspect_mapped_class(class, configure=configure)
Feb 12 16:05:33 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/base.py", line 430, in inspect_mapped_class
Feb 12 16:05:33 localhost uwsgi[1790]: mapper.configure_all()
Feb 12 16:05:33 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/mapper.py", line 1352, in _configure_all
Feb 12 16:05:33 localhost uwsgi[1790]: configure_mappers()
Feb 12 16:05:33 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/mapper.py", line 3295, in configure_mappers
Feb 12 16:05:33 localhost uwsgi[1790]: raise e
Feb 12 16:05:33 localhost uwsgi[1790]: sqlalchemy.exc.InvalidRequestError: One or more mappers failed to initialize - can't proceed with initialization of other mappers. Triggering mapper: 'mapped class Users->users'. Original exception was: When initializing mapper mapped class Users->users, expression 'admin_user_role_relation' failed to locate a name ("name 'admin_user_role_relation' is not defined"). If this is a class name, consider adding this relationship() to the <class 'orm.users.Users'> class after both dependent classes have been defined.
Feb 12 16:05:33 localhost uwsgi[1790]: [WARNING] (flask.app) GET /api/v1/service/syncPolicy/andreas.kaelber@tsu-pe.de? from ::1 -> 500 '{"message":"The server encountered an error while processing the request."}\n'
Feb 12 16:05:33 localhost sshd[613]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:33 localhost sshd[613]: Connection closed by 127.0.0.1 port 51600
Feb 12 16:05:34 localhost sshd[882]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:34 localhost sshd[882]: Connection closed by 127.0.0.1 port 51614
Feb 12 16:05:35 localhost sshd[885]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:35 localhost sshd[885]: Connection closed by 127.0.0.1 port 51618
Feb 12 16:05:36 localhost sshd[888]: error: kex_exchange_identification: Connection closed by remote host
Feb 12 16:05:36 localhost sshd[888]: Connection closed by 127.0.0.1 port 51630
Feb 12 16:05:36 localhost uwsgi[1790]: [ERROR] (flask.app) Traceback (most recent call last):
Feb 12 16:05:36 localhost uwsgi[1790]: File "/usr/lib/python3.6/site-packages/flask/app.py", line 1838, in full_dispatch_request
Feb 12 16:05:36 localhost uwsgi[1790]: rv = self.dispatch_request()
Feb 12 16:05:36 localhost uwsgi[1790]: File "/usr/lib/python3.6/site-packages/flask/app.py", line 1824, in dispatch_request
Feb 12 16:05:36 localhost uwsgi[1790]: return self.view_functionsrule.endpoint
Feb 12 16:05:36 localhost uwsgi[1790]: File "./api/core.py", line 179, in wrapper
Feb 12 16:05:36 localhost uwsgi[1790]: return call()
Feb 12 16:05:36 localhost uwsgi[1790]: File "./api/core.py", line 144, in call
Feb 12 16:05:36 localhost uwsgi[1790]: ret = func(*args, **kwargs)
Feb 12 16:05:36 localhost uwsgi[1790]: File "./endpoints/service.py", line 32, in getUserSyncPolicy
Feb 12 16:05:36 localhost uwsgi[1790]: user = Users.query.filter(Users.username == username).first()
Feb 12 16:05:36 localhost uwsgi[1790]: File "./orm/init.py", line 32, in get
Feb 12 16:05:36 localhost uwsgi[1790]: mapper = class_mapper(type)
Feb 12 16:05:36 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/base.py", line 451, in class_mapper
Feb 12 16:05:36 localhost uwsgi[1790]: mapper = inspect_mapped_class(class, configure=configure)
Feb 12 16:05:36 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/base.py", line 430, in inspect_mapped_class
Feb 12 16:05:36 localhost uwsgi[1790]: mapper.configure_all()
Feb 12 16:05:36 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/mapper.py", line 1352, in _configure_all
Feb 12 16:05:36 localhost uwsgi[1790]: configure_mappers()
Feb 12 16:05:36 localhost uwsgi[1790]: File "/usr/lib64/python3.6/site-packages/sqlalchemy/orm/mapper.py", line 3295, in configure_mappers
Feb 12 16:05:36 localhost uwsgi[1790]: raise e
Feb 12 16:05:36 localhost uwsgi[1790]: sqlalchemy.exc.InvalidRequestError: One or more mappers failed to initialize - can't proceed with initialization of other mappers. Triggering mapper: 'mapped class Users->users'. Original exception was: When initializing mapper mapped class Users->users, expression 'admin_user_role_relation' failed to locate a name ("name 'admin_user_role_relation' is not defined"). If this is a class name, consider adding this relationship() to the <class 'orm.users.Users'> class after both dependent classes have been defined.
Feb 12 16:05:36 localhost uwsgi[1790]: [WARNING] (flask.app) GET /api/v1/service/syncPolicy/andreas.kaelber@tsu-pe.de? from ::1 -> 500 '{"message":"The server encountered an error while processing the request."}\n'
--- Abbruch durch User ---
localhost:~ #
tail /var/log/grommunio/* -f zeigte m.E. nichts auffälliges
