antipiot WalterH yes, but i fixed it and it's still occuring. And as you can see in logs, theres likely no error. Dont know what to say and how to help more...
antipiot WalterH Ok. It looks to be ipv6 related probably. Disabling ipv6 (wich i dont need to use) leads to error 500. Any hint?
antipiot WalterH New problem: the server started to use IPV6 for no reason and that IP has no PTR entry, so mail get rejected. I've only configured IPv4 in network settings. How can i solve that? 1 more problem to solve yay! 🙂
WalterH This is yast, the system SUSE configuration utility. There are also other settings that make the system unusable. The system does not need an IPv6 address, only the IPv6 stack must be enabled. That was the default configuration.
antipiot Solution for emails being sent over ipv6 instead of ipv4 causing a PTR error on the recipient side: just enter this command postconf -e "inet_protocols = ipv4"
WalterH If I interpret your last posts correctly, the error 500 is solved and sending mail when IPv6 is enabled is also solved.
antipiot WalterH Sorry about the misunderstanding. Sending mail is indeed fixed. but i still have no console and error 500 / no console once i go for the update.
Andy Wie sind auch hier die Versionen? localhost:~ # rpm -qi gromox | head -n 3 Name : gromox Version : 2.2.140.7f3e6a0 Release : lp154.112.1 localhost:~ #
WalterH Nach dem aktuellen Update: # rpm -qi gromox | head -n 3 Name : gromox Version : 2.3.84.1194373 Release : lp153.55.1
THE_FRICKLER rpm -qi gromox | head -n 3 Name : gromox Version : 2.3.102.2bf5713 Release : lp154.57.1 Community
antipiot Well, out of nowere and for no reason, i get this error whyen i try to send an email. it's a simple test mail, no attachement rpm -qi gromox | head -n 3 rpm -qi gromox | head -n 3 Name : gromox Version : 2.3.106.d34a0e9 Release : lp153.58.1
antipiot nginx-web-error.log: FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught MAPIException: 2023/02/20 08:54:41 [error] 1706#1706: *5 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught MAPIException: The operation failed for an unspecified reason in /usr/share/grommunio-web/server/includes/core/class.mapisession.php:580 Stack trace: #0 /usr/share/grommunio-web/server/includes/core/class.mapisession.php(580): mapi_table_queryallrows(Resource id #95, Array) #1 /usr/share/grommunio-web/server/includes/core/class.mapisession.php(617): MAPISession->loadMessageStoresFromSession() #2 /usr/share/grommunio-web/server/includes/core/class.mapisession.php(121): MAPISession->getDefaultMessageStore() #3 /usr/share/grommunio-web/server/includes/core/class.mapisession.php(482): MAPISession->getUser() #4 /usr/share/grommunio-web/server/includes/core/class.mapisession.php(491): MAPISession->getDisabledFeatures() #5 /usr/share/grommunio-web/index.php(178): MAPISession->isWebappDisableAsFeature() #6 {main} thrown in /usr/share/grommunio-web/server/includes/core/class.mapisession.php on line 580" while reading response header from upstream, client: 10.0.0.49, server: _, request: "GET /web/ HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/grommunio-web:", host: "mail.domain.tld" !<
Johan Ik have have exacly the same error after the update last weekend. nginx not started in the console can login in the webbrowser. if i try to send an mail i get "TypeError: g.isMeetingSent is not a function" can somebody please help?
