• Info
  • Update form Open SuSE 15.3 to 15.4
Maybe I do wrong. I did --> cat /etc/SUSE-brand
upstream
VERSION = 12.3
CO-BRANDS = openSUSE SLED SLES SLE
I did administer OES servers for years based on Suse enterprise and that was the command to validate versions and patches.
Good thing if I'm wrong with Grommunio.. I'm learning everyday.. ...
    Please post content of: /etc/zypp/repos.d/grommunio.repo , if you have password for supported repository in this file, mask the password and username.
    bunker
    Hi Bunker,
    your server should be on 15.3.
    on one of my servers is 15.3 it looks like:
    node01:/etc # cat SUSE-brand
    upstream
    VERSION = 12.3
    node01:/etc # cat os-release
    NAME="grommunio"
    VERSION="2022.05.2"
    ID="grommunio-lds"
    ID_LIKE="suse"
    VERSION_ID="2022.05.2"
    PRETTY_NAME="grommunio"
    ANSI_COLOR="0;36"
    HOME_URL="https://grommunio.com/"
    DOCUMENTATION_URL="https://docs.grommunio.com/"
    9 months later
    WalterH, sorry to be late. I'm now back at our internal "grommunio project"and need to solve why I cannot receive any more updates. My goal is to run on latest version.
    Here is my output of /etc/zypp/repos.d/grommunio.repo
    [grommunio]
    name=grommunio
    enabled=1
    autorefresh=1
    baseurl=https://download.grommunio.com/community/openSUSE_Leap_15.3/?ssl_verify=no
    path=/
    type=rpm-md
    keeppackages=0
    And my system ->
    cat /etc/os-release
    NAME="grommunio"
    VERSION="2022.05.2"
    ID="grommunio-lds"
    ID_LIKE="suse"
    ANSI_COLOR="0;36"
    cat /etc/SUSE-brand
    upstream
    VERSION = 12.3
    When I run zypper up:
    zypper up
    Loading repository data...
    Warning: Repository 'repo-backports-update' appears to be outdated. Consider using a different mirror or server.
    Warning: Repository 'update' appears to be outdated. Consider using a different mirror or server.
    Reading installed packages...
    The following item is locked and will not be changed by any action:
    Installed:
    grommunio-files
    The following package update will NOT be installed:
    grommunio-files
    Nothing to do.
    Is it normal to be stuck there? Should I upgrade to a new version of appliance?
    I thank you all for your help.
    Try to follow the procedure and ignore this errors and hope, that step 10. upgrades to 15.4.
    And than upgrade to 15.5.
      Alternatively, use grommunio-update upgrade whish does this automagically for you.
        WalterH most commands you may copy and paste the command to the grommunio server
        Hi Guys,
        Thanks for your quick replies. I do really appreciate.
        I tried WalterH procedure "A recipe to update grommunio from Open SuSE 15.3 to 15.4."
        It didn't work.
        First when it asked to uninstall PHP7 with rpm -e php7-opcache
        I did receive a message that it is not installed. -->
        mail4:~ # rpm -e php7-opcache
        error: package php7-opcache is not installed
        Second, it stuck a the gromox update point. -->
        zypper update gromox
        Resolving package dependencies...
        Problem: the to be installed gromox-2.20.6.g19e4a21-lp154.16.1.x86_64 requires 'php8-soap', but this requirement cannot be provided
        not installable providers: php8-soap-8.0.10-150400.2.7.x86_64[base]
        php8-soap-8.0.10-150400.4.3.1.x86_64[repo-sle-update]
        php8-soap-8.0.10-150400.4.8.1.x86_64[repo-sle-update]
        php8-soap-8.0.24-150400.4.14.1.x86_64[repo-sle-update]
        php8-soap-8.0.25-150400.4.17.1.x86_64[repo-sle-update]
        php8-soap-8.0.25-150400.4.20.1.x86_64[repo-sle-update]
        php8-soap-8.0.27-150400.4.23.1.x86_64[repo-sle-update]
        php8-soap-8.0.28-150400.4.26.1.x86_64[repo-sle-update]
        php8-soap-8.0.28-150400.4.31.1.x86_64[repo-sle-update]
        php8-soap-8.0.29-150400.4.34.1.x86_64[repo-sle-update]
        php8-soap-8.0.30-150400.4.37.1.x86_64[repo-sle-update]
        Solution 1: Following actions will be done:
        deinstallation of php7-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-zlib-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-zip-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-xmlwriter-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-xmlreader-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-sysvshm-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-sqlite-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-sodium-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-soap-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-posix-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-pdo-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-pcntl-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-openssl-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-mysql-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-mbstring-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-ldap-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-intl-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-iconv-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-gmp-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-gettext-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-gd-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-ftp-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-fpm-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-fileinfo-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-dom-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-curl-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-ctype-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-bz2-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-bcmath-7.4.33-150200.3.46.2.x86_64
        deinstallation of php7-APCu-5.1.18-bp153.1.17.x86_64
        deinstallation of php7-imagick-3.4.4-bp153.1.18.x86_64
        deinstallation of php7-memcached-3.1.5-bp153.1.16.x86_64
        deinstallation of php7-pear-1.10.21-3.6.1.noarch
        deinstallation of php7-redis-5.2.2-bp153.1.17.x86_64
        deinstallation of php7-smbclient-1.0.0-bp153.1.20.x86_64
        Solution 2: do not install gromox-2.20.6.g19e4a21-lp154.16.1.x86_64
        Solution 3: break gromox-2.20.6.g19e4a21-lp154.16.1.x86_64 by ignoring some of its dependencies
        Choose from above solutions by number or cancel [1/2/3/c/d/?] (c): 1
        Resolving dependencies...
        2 Problems:
        Problem: the installed grommunio-files-10.9.1-lp153.1.1.noarch requires 'php7-APCu', but this requirement cannot be provided
        Problem: the installed grommunio-files-10.9.1-lp153.1.1.noarch requires 'php7-curl', but this requirement cannot be provided
        deleted providers: php7-APCu-5.1.18-bp153.1.17.x86_64
        not installable providers: php7-APCu-5.1.18-bp154.1.25.x86_64[base]
        php7-APCu-5.1.22-bp154.2.1.i586[repo-backports-update]
        php7-APCu-5.1.22-bp154.2.1.x86_64[repo-backports-update]
        keep php7-APCu-5.1.18-bp153.1.17.x86_64
        keep php7-fileinfo-7.4.33-150200.3.46.2.x86_64
        keep php7-intl-7.4.33-150200.3.46.2.x86_64
        keep php7-ldap-7.4.33-150200.3.46.2.x86_64
        keep php7-smbclient-1.0.0-bp153.1.20.x86_64
        keep php7-openssl-7.4.33-150200.3.46.2.x86_64
        Solution 2: remove lock to allow removal of grommunio-files-10.9.1-lp153.1.1.noarch
        Solution 3: break grommunio-files-10.9.1-lp153.1.1.noarch by ignoring some of its dependencies
        Choose from above solutions by number or skip, retry or cancel [1/2/3/s/r/c/d/?] (c): 2
        deleted providers: php7-curl-7.4.33-150200.3.46.2.x86_64
        not installable providers: php7-curl-7.4.25-150400.2.7.x86_64[base]
        php7-curl-7.4.25-150400.4.3.1.x86_64[repo-sle-update]
        php7-curl-7.4.25-150400.4.8.1.x86_64[repo-sle-update]
        php7-curl-7.4.33-150400.4.13.1.x86_64[repo-sle-update]
        php7-curl-7.4.33-150400.4.16.1.x86_64[repo-sle-update]
        php7-curl-7.4.33-150400.4.19.1.x86_64[repo-sle-update]
        php7-curl-7.4.33-150400.4.22.1.x86_64[repo-sle-update]
        php7-curl-7.4.33-150400.4.25.1.x86_64[repo-sle-update]
        php7-curl-7.4.33-150400.4.28.1.x86_64[repo-sle-update]
        keep php7-curl-7.4.33-150200.3.46.2.x86_64
        Solution 2: deinstallation of grommunio-files-10.9.1-lp153.1.1.noarch
        Solution 3: remove lock to allow installation of grommunio-files-25.0.13-lp154.2.1.noarch[grommunio]
        Solution 4: remove lock to allow installation of grommunio-files-25.0.13-lp154.1.1.noarch[grommunio]
        Solution 5: break grommunio-files-10.9.1-lp153.1.1.noarch by ignoring some of its dependencies
        At this point, I decided to rollback..
        What should I do ?
        Big thanks for your good work and help!
        Hi guys,
        I'm still stuck with my appliance that refuse to update. No customisation done..
        It's quite hard to maintain this appliance..
        I tried to run grommunio-update command tool as mentioned by MWilliams. Still no luck.
        Any help will be appreciate.
                                               _                       __     __
          ___ ________  __ _  __ _  __ _____  (_)__  ______ _____  ___/ /__ _/ /____
         / _ \/ __/ _ \/  ' \/  ' \/ // / _ \/ / _ \/___/ // / _ \/ _  / _ \/ __/ -_)
         \_, /_/  \___/_/_/_/_/_/_/\_,_/_//_/_/\___/    \_,_/ .__/\_,_/\_,_/\__/\__/
        /___/                                              /_/
        ## This system	: xxxx
        ## Uptime	: 0:01
        ## Load		: Last Minute: 1.28, Last 5 Minutes: 0.35, Last 15 Minutes: 0.12
        ## IP Address	: 192.168.xx.xx
        ## Executed	: /usr/sbin/grommunio-update upgrade
        ## Start	: Sat 2023-12-23 10:35:01 EST
        ## Operation	: Upgrade
        ▶ Starting Upgrade (zypper ref && zypper dup -y)
        Repository 'base' is up to date.
        Repository 'debug' is up to date.
        Repository 'grommunio' is up to date.
        Repository 'repo-backports-update' is up to date.
        Repository 'repo-sle-update' is up to date.
        Repository 'update' is up to date.
        All repositories have been refreshed.
        Warning: You are about to do a distribution upgrade with all enabled repositories. Make sure these repositories are compatible before you continue. See 'man zypper' for more information about this command.
        Computing distribution upgrade...
        10 Problems:
        Problem: problem with the installed dracut-kiwi-lib-9.24.48-lp153.1.1.x86_64
        Problem: problem with the installed dracut-kiwi-live-9.24.48-lp153.1.1.x86_64
        Problem: problem with the installed dracut-kiwi-oem-dump-9.24.48-lp153.1.1.x86_64
        Problem: problem with the installed dracut-kiwi-oem-repart-9.24.48-lp153.1.1.x86_64
        Problem: problem with the installed kiwi-systemdeps-bootloaders-9.24.48-lp153.1.1.x86_64
        Problem: problem with the installed kiwi-systemdeps-core-9.24.48-lp153.1.1.x86_64
        Problem: problem with the installed kiwi-systemdeps-disk-images-9.24.48-lp153.1.1.x86_64
        Problem: problem with the installed kiwi-systemdeps-filesystems-9.24.48-lp153.1.1.x86_64
        Problem: problem with the installed kiwi-systemdeps-iso-media-9.24.48-lp153.1.1.x86_64
        Problem: problem with the installed kiwi-tools-9.24.48-lp153.1.1.x86_64
         Solution 1: install dracut-kiwi-lib-9.24.43-150100.3.56.3.x86_64 from vendor SUSE LLC <https://www.suse.com/>
          replacing dracut-kiwi-lib-9.24.48-lp153.1.1.x86_64 from vendor obs://build.opensuse.org/Virtualization:Appliances
         Solution 2: keep obsolete dracut-kiwi-lib-9.24.48-lp153.1.1.x86_64
        Choose from above solutions by number or skip, retry or cancel [1/2/s/r/c/d/?] (c): c
        ▶ Upgrade failed with exit status 4, please check the log /var/log/grommunio-update.log
        Content of the var/log/grommunio-update.log-->
        ## Uptime       : 0:01
        ## IP Address   : 192.168.x.x
        ^[[36m▶^[[0m Starting Upgrade (zypper ref && zypper dup -y)
        10 Problems:
        ^[[31m▶^[[0m Upgrade failed with exit status 4, please check the log /var/log/grommunio-update.log
        ## End Upgrade  :Sat 2023-12-23 10:35:11 EST
          bunker Problem: problem with the installed dracut-kiwi-lib-9.24.48-lp153.1.1.x86_64
          I would try to perform the update manually with zypper dup and answer Zypper's questions correctly. Change the repositories correctly beforehand. First go to 15.4 and only update to 15.5 in the 2nd step.
          22 days later
          Hi Walter,
          I did what you suggested me.
          Upgrade went through. Thanks for the procedure.
          System is working in exception of FILES.. I have a Error 404 - Not Found.
          I'm sure I did follow all steps. Before I rety for a third time. Maybe you or somebody else have a suggestion to where looking at?
          Try the grommunio-update update command and if this do not help, look in the logs:
          system-d log:
          journalctl -f
          nginx logs:
          tail /var/log/nginx/*.log -f
          It looks like it may be a permission issues. But I don't know how to fix it.
          I really do appreciate your help.
          journalctl -f
          ==> /var/log/nginx/error.log <==
          2024/01/12 00:00:04 [emerg] 1534#1534: open() "/var/log/grommunio/nginx-files-access.log" failed (13: Permission denied)
          2024/01/12 00:00:04 [emerg] 1534#1534: open() "/var/log/grommunio/nginx-files-error.log" failed (13: Permission denied)
          2024/01/13 00:00:02 [notice] 25464#25464: signal process started
          2024/01/13 00:00:02 [emerg] 1534#1534: open() "/var/log/grommunio/nginx-files-access.log" failed (13: Permission denied)
          2024/01/13 00:00:02 [emerg] 1534#1534: open() "/var/log/grommunio/nginx-files-error.log" failed (13: Permission denied)
          2024/01/15 00:00:11 [notice] 18486#18486: signal process started
          2024/01/15 00:00:11 [emerg] 1534#1534: open() "/var/log/grommunio/nginx-files-access.log" failed (13: Permission denied)
          2024/01/15 00:00:11 [emerg] 1534#1534: open() "/var/log/grommunio/nginx-files-error.log" failed (13: Permission denied)
          2024/01/16 00:00:02 [notice] 10533#10533: signal process started
          2024/01/16 00:09:39 [emerg] 24552#24552: module "/usr//lib64/nginx/modules/ngx_http_brotli_static_module.so" version 1019008 instead of 1021005 in /etc/nginx/nginx.conf:4
          ==> /var/log/nginx/nginx-access.log <==
          10.11.11.21 - - [16/Jan/2024:20:10:10 -0500] "GET / HTTP/2.0" 301 162 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:12 -0500] "GET /web/client/resources/fonts/roboto-400-latin.woff2 HTTP/2.0" 200 15744 "https://10.1.1.70/web/client/resources/css/grommunio.css?version=3.6.15.42597875-lp155.15.1" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:14 -0500] "GET /web/client/resources/fonts/roboto-700-latin.woff2 HTTP/2.0" 200 15860 "https://10.1.1.70/web/client/resources/css/grommunio.css?version=3.6.15.42597875-lp155.15.1" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:14 -0500] "GET /web/client/resources/fonts/roboto-400-italic-latin.woff2 HTTP/2.0" 200 17368 "https://10.1.1.70/web/client/resources/css/grommunio.css?version=3.6.15.42597875-lp155.15.1" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.1.1.70 - john@network.com [16/Jan/2024:20:10:14 -0500] "PROPFIND /files/remote.php/webdav/ HTTP/2.0" 405 10946 "-" "sabre-dav/4.4.0 (http://sabre.io/)"
          10.11.11.21 - - [16/Jan/2024:20:10:14 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 500 10782 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:24 -0500] "GET /pwa-worker.js HTTP/2.0" 200 1246 "https://10.1.1.70/meet/" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:27 -0500] "GET /files HTTP/2.0" 404 4720 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:27 -0500] "GET /_errors/main.css HTTP/2.0" 200 918 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          ==> /var/log/nginx/nginx-admin-access.log <==
          ::1 - - [15/Jan/2024:15:15:13 -0500] "GET /api/v1/service/syncPolicy/john@network.com HTTP/1.0" 200 928 "-" "-"
          ::1 - - [15/Jan/2024:15:15:30 -0500] "GET /api/v1/service/wipe/john@network.com?devices=sec19c2158abc31a HTTP/1.0" 200 43 "-" "-"
          ::1 - - [15/Jan/2024:15:15:31 -0500] "GET /api/v1/service/wipe/john@network.com?devices=sec19c2158abc31a HTTP/1.0" 200 43 "-" "-"
          ::1 - - [15/Jan/2024:15:15:31 -0500] "POST /api/v1/service/wipe/john@network.com?devices=sec19c2158abc31a HTTP/1.0" 201 23 "-" "-"
          ::1 - - [15/Jan/2024:21:22:21 -0500] "GET /api/v1/status HTTP/1.0" 200 61 "-" "-"
          ::1 - - [15/Jan/2024:21:22:23 -0500] "GET /api/v1/status HTTP/1.0" 200 61 "-" "-"
          ::1 - - [16/Jan/2024:11:54:02 -0500] "GET /api/v1/status HTTP/1.1" 200 61 "-" "-"
          ::1 - - [16/Jan/2024:11:54:04 -0500] "GET /api/v1/status HTTP/1.1" 200 61 "-" "-"
          ::1 - - [16/Jan/2024:20:10:10 -0500] "GET /api/v1/status HTTP/1.1" 200 61 "-" "-"
          ::1 - - [16/Jan/2024:20:10:12 -0500] "GET /api/v1/status HTTP/1.1" 200 61 "-" "-"
          ==> /var/log/nginx/nginx-admin-error.log <==
          ==> /var/log/nginx/nginx-archive-access.log <==
          ==> /var/log/nginx/nginx-archive-error.log <==
          ==> /var/log/nginx/nginx-autodiscover-access.log <==
          142.116.39.80 - - [15/Jan/2024:14:12:06 -0500] "POST /autodiscover/autodiscover.xml HTTP/2.0" 401 14 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - - [15/Jan/2024:14:12:08 -0500] "POST /autodiscover/autodiscover.xml HTTP/2.0" 401 14 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:14:12:12 -0500] "POST /autodiscover/autodiscover.xml HTTP/2.0" 200 2470 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:10:56 -0500] "POST /autodiscover/autodiscover.xml HTTP/2.0" 200 3420 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:11:29 -0500] "POST /autodiscover/autodiscover.xml HTTP/2.0" 200 3420 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - - [15/Jan/2024:15:11:29 -0500] "GET /autodiscover/autodiscover.json/v1.0/francois@fyelle.com?Protocol=REST&RedirectCount=1 HTTP/1.1" 200 28 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - - [15/Jan/2024:15:11:30 -0500] "GET /autodiscover/autodiscover.json/v1.0/francois@fyelle.com?Protocol=Autodiscoverv1&RedirectCount=1 HTTP/1.1" 200 97 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - - [15/Jan/2024:15:12:12 -0500] "POST /autodiscover/autodiscover.xml HTTP/2.0" 401 14 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - - [15/Jan/2024:15:12:14 -0500] "POST /autodiscover/autodiscover.xml HTTP/2.0" 401 14 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:12:18 -0500] "POST /autodiscover/autodiscover.xml HTTP/2.0" 200 2470 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          ==> /var/log/nginx/nginx-autodiscover-error.log <==
          2023/11/14 23:43:36 [error] 1591#1591: *115319 connect() failed (111: Connection refused) while connecting to upstream, client: 10.1.1.70, server: _, request: "POST /autodiscover/autodiscover.xml HTTP/1.1", upstream: "https://127.0.0.1:10443/autodiscover/autodiscover.xml", host: "autodiscover.domain.com"
          2023/11/14 23:43:36 [error] 1591#1591: *115319 connect() failed (111: Connection refused) while connecting to upstream, client: 10.1.1.70, server: _, request: "POST /autodiscover/autodiscover.xml HTTP/1.1", upstream: "https://[::1]:10443/autodiscover/autodiscover.xml", host: "autodiscover.domain.com"
          2023/11/14 23:43:39 [error] 1591#1591: *115327 no live upstreams while connecting to upstream, client: 10.1.1.70, server: _, request: "POST /autodiscover/autodiscover.xml HTTP/1.1", upstream: "https://gromoxhttp/autodiscover/autodiscover.xml", host: "autodiscover.domain.com"
          2023/11/14 23:43:41 [error] 1591#1591: *115330 no live upstreams while connecting to upstream, client: 10.1.1.70, server: _, request: "POST /autodiscover/autodiscover.xml HTTP/1.1", upstream: "https://gromoxhttp/autodiscover/autodiscover.xml", host: "autodiscover.domain.com"
          ==> /var/log/nginx/nginx-chat-access.log <==
          10.11.11.21 - - [16/Jan/2024:20:10:26 -0500] "GET /chat/api/v4/files/xoffqxxnajne7fkmsxkc9bjwhe/preview HTTP/2.0" 200 155534 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:26 -0500] "GET /chat/api/v4/users/ff63f3wzdfybdrxg7dxxd6xb1w/image?=0 HTTP/2.0" 200 843 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:26 -0500] "GET /chat/api/v4/users/beqw6rymkfgtddn5r1onk53tmh/image?
          =0 HTTP/2.0" 200 727 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:26 -0500] "GET /chat/api/v4/users/so9r7cc39tnt8qa4e44693eewr/image?=0 HTTP/2.0" 200 2104 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:26 -0500] "GET /chat/api/v4/users/z9gwtahmityp58z8sh8n6seaoe/image?
          =0 HTTP/2.0" 200 824 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:26 -0500] "GET /chat/static/files/20fd1704ea223900efa9fd4e869efb08.woff2 HTTP/2.0" 200 77190 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:26 -0500] "GET /chat/api/v4/users/wkbi6tj51pngi8cizmo4f9cjfy/image?_=0 HTTP/2.0" 200 1515 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:26 -0500] "GET /chat/api/v4/files/am1ykjj3oi87tckik9ofzqe6ea/thumbnail HTTP/2.0" 200 7020 "https://10.1.1.70/chat/americmedia/channels/town-square" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:26 -0500] "GET /chat/api/v4/files/471fsrj5bjrsfb58wspwx1hjic/thumbnail HTTP/2.0" 200 6354 "https://10.1.1.70/chat/americmedia/channels/town-square" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:11:16 -0500] "POST /chat/api/v4/users/status/ids HTTP/2.0" 200 408 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          ==> /var/log/nginx/nginx-chat-error.log <==
          2024/01/05 09:29:21 [error] 1881#1881: *272511 connect() failed (111: Connection refused) while connecting to upstream, client: 10.1.1.70, server: _, request: "GET /chat/api/v4/users/me/teams/unread?include_collapsed_threads=false HTTP/2.0", upstream: "http://127.0.0.1:8065/chat/api/v4/users/me/teams/unread?include_collapsed_threads=false", host: "mail4.domain.com"
          2024/01/05 09:29:21 [error] 1881#1881: *272511 connect() failed (111: Connection refused) while connecting to upstream, client: 10.1.1.70, server: _, request: "GET /chat/api/v4/plugins/webapp HTTP/2.0", upstream: "http://127.0.0.1:8065/chat/api/v4/plugins/webapp", host: "mail4.domain.com"
          2024/01/05 09:29:21 [error] 1881#1881: *272511 connect() failed (111: Connection refused) while connecting to upstream, client: 10.1.1.70, server: _, request: "POST /chat/api/v4/users/ids?since=1703707230344 HTTP/2.0", upstream: "http://127.0.0.1:8065/chat/api/v4/users/ids?since=1703707230344", host: "mail4.domain.com"
          2024/01/05 09:29:26 [error] 1881#1881: *272552 connect() failed (111: Connection refused) while connecting to upstream, client: 10.1.1.70, server: _, request: "GET /chat/api/v4/websocket?connection_id=ihagwc6kx7dp3n4daaby3egm3o&sequence_number=48 HTTP/1.1", upstream: "http://127.0.0.1:8065/chat/api/v4/websocket?connection_id=ihagwc6kx7dp3n4daaby3egm3o&sequence_number=48", host: "mail4.domain.com"
          2024/01/05 09:29:26 [error] 1881#1881: *272556 connect() failed (111: Connection refused) while connecting to upstream, client: 10.1.1.70, server: _, request: "GET /chat/api/v4/websocket?connection_id=r4stjfq7xjfx8jzdfnm46dw9ke&sequence_number=206 HTTP/1.1", upstream: "http://127.0.0.1:8065/chat/api/v4/websocket?connection_id=r4stjfq7xjfx8jzdfnm46dw9ke&sequence_number=206", host: "mail4.domain.com"
          2024/01/16 11:56:46 [error] 1871#1871: *2 connect() failed (111: Connection refused) while connecting to upstream, client: 10.11.11.21, server: _, request: "GET /chat/api/v4/websocket?connection_id=mmn67hfec3fxzg53x7wx1gw4hh&sequence_number=5 HTTP/1.1", upstream: "http://127.0.0.1:8065/chat/api/v4/websocket?connection_id=mmn67hfec3fxzg53x7wx1gw4hh&sequence_number=5", host: "10.1.1.70"
          2024/01/16 12:14:36 [error] 1552#1552: *2 connect() failed (111: Connection refused) while connecting to upstream, client: 10.11.11.21, server: _, request: "GET /chat/api/v4/websocket?connection_id=kmordwf39pr5tk1uw54hkzd5iy&sequence_number=2 HTTP/1.1", upstream: "http://127.0.0.1:8065/chat/api/v4/websocket?connection_id=kmordwf39pr5tk1uw54hkzd5iy&sequence_number=2", host: "10.1.1.70"
          2024/01/16 12:14:39 [error] 1552#1552: *12 connect() failed (111: Connection refused) while connecting to upstream, client: 10.11.11.21, server: _, request: "GET /chat/api/v4/websocket?connection_id=kmordwf39pr5tk1uw54hkzd5iy&sequence_number=2 HTTP/1.1", upstream: "http://127.0.0.1:8065/chat/api/v4/websocket?connection_id=kmordwf39pr5tk1uw54hkzd5iy&sequence_number=2", host: "10.1.1.70"
          2024/01/16 12:14:41 [error] 1552#1552: *5 connect() failed (111: Connection refused) while connecting to upstream, client: 10.11.11.21, server: _, request: "POST /chat/api/v4/users/status/ids HTTP/2.0", upstream: "http://127.0.0.1:8065/chat/api/v4/users/status/ids", host: "10.1.1.70"
          2024/01/16 12:14:43 [error] 1552#1552: *16 connect() failed (111: Connection refused) while connecting to upstream, client: 10.11.11.21, server: _, request: "GET /chat/api/v4/websocket?connection_id=kmordwf39pr5tk1uw54hkzd5iy&sequence_number=2 HTTP/1.1", upstream: "http://127.0.0.1:8065/chat/api/v4/websocket?connection_id=kmordwf39pr5tk1uw54hkzd5iy&sequence_number=2", host: "10.1.1.70"
          ==> /var/log/nginx/nginx-dav-access.log <==
          184.107.122.130 - john@network.com [15/Jan/2024:13:29:49 -0500] "GET /dav HTTP/1.0" 200 4233 "-" "-"
          184.107.122.130 - john@network.com [15/Jan/2024:13:29:50 -0500] "GET /dav HTTP/1.0" 200 4233 "-" "-"
          184.107.122.130 - john@network.com [15/Jan/2024:13:29:51 -0500] "GET /dav HTTP/1.0" 200 4233 "-" "-"
          184.107.122.130 - john@network.com [15/Jan/2024:13:29:52 -0500] "GET /dav HTTP/1.0" 200 4233 "-" "-"
          184.107.122.130 - john@network.com [15/Jan/2024:15:08:54 -0500] "GET /dav HTTP/1.0" 200 4233 "-" "-"
          184.107.122.130 - john@network.com [15/Jan/2024:15:09:04 -0500] "GET /dav HTTP/1.0" 200 4233 "-" "-"
          184.107.122.130 - john@network.com [15/Jan/2024:15:09:05 -0500] "GET /dav HTTP/1.0" 200 4233 "-" "-"
          184.107.122.130 - john@network.com [15/Jan/2024:15:09:06 -0500] "GET /dav HTTP/1.0" 200 4233 "-" "-"
          ==> /var/log/nginx/nginx-dav-error.log <==
          2024/01/15 13:29:49 [error] 1534#1534: *132233 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 184.107.122.130, server: _, request: "GET /dav HTTP/1.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-dav-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 13:29:50 [error] 1534#1534: *132279 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 184.107.122.130, server: _, request: "GET /dav HTTP/1.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-dav-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 13:29:51 [error] 1534#1534: *132282 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 184.107.122.130, server: _, request: "GET /dav HTTP/1.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-dav-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 13:29:51 [error] 1534#1534: *132285 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 184.107.122.130, server: _, request: "GET /dav HTTP/1.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-dav-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 13:29:52 [error] 1534#1534: *132289 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 184.107.122.130, server: _, request: "GET /dav HTTP/1.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-dav-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:08:54 [error] 1534#1534: *134307 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 184.107.122.130, server: _, request: "GET /dav HTTP/1.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-dav-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:09:04 [error] 1534#1534: *134355 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 184.107.122.130, server: _, request: "GET /dav HTTP/1.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-dav-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:09:05 [error] 1534#1534: *134358 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 184.107.122.130, server: _, request: "GET /dav HTTP/1.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-dav-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:09:05 [error] 1534#1534: *134361 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 184.107.122.130, server: _, request: "GET /dav HTTP/1.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-dav-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:09:06 [error] 1534#1534: *134366 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 184.107.122.130, server: _, request: "GET /dav HTTP/1.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-dav-fpm.sock:", host: "mail4.domain.com"
          ==> /var/log/nginx/nginx-error.log <==
          2024/01/15 10:11:23 [error] 1534#1534: *128588 open() "/srv/jitsi-meet/.env" failed (2: No such file or directory), client: 35.216.180.106, server: _, request: "GET /.env HTTP/1.1", host: "184.107.122.130"
          2024/01/15 10:11:23 [error] 1534#1534: *128589 open() "/srv/jitsi-meet/telescope/requests" failed (2: No such file or directory), client: 35.216.180.106, server: _, request: "GET /telescope/requests HTTP/1.1", host: "184.107.122.130"
          2024/01/15 10:11:24 [error] 1534#1534: *128590 open() "/srv/jitsi-meet/info.php" failed (2: No such file or directory), client: 35.216.180.106, server: _, request: "GET /info.php HTTP/1.1", host: "184.107.122.130"
          2024/01/15 10:19:03 [crit] 1534#1534: *128737 SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking, client: 106.75.99.41, server: 0.0.0.0:443
          2024/01/15 11:52:40 [crit] 1534#1534: *130923 SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking, client: 101.68.211.2, server: 0.0.0.0:443
          2024/01/15 12:57:57 [crit] 1534#1534: *131737 SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking, client: 71.6.165.200, server: 0.0.0.0:443
          2024/01/15 12:58:11 [error] 1534#1534: *131748 open() "/srv/jitsi-meet/sitemap.xml" failed (2: No such file or directory), client: 71.6.165.200, server: _, request: "GET /sitemap.xml HTTP/1.1", host: "184.107.122.130"
          2024/01/15 12:58:12 [error] 1534#1534: *131749 open() "/srv/jitsi-meet/.well-known/security.txt" failed (2: No such file or directory), client: 71.6.165.200, server: _, request: "GET /.well-known/security.txt HTTP/1.1", host: "184.107.122.130"
          2024/01/16 11:55:43 [error] 9288#9288: *2 open() "/srv/jitsi-meet/files" failed (2: No such file or directory), client: 10.11.11.21, server: _, request: "GET /files HTTP/2.0", host: "10.1.1.70"
          2024/01/16 20:10:27 [error] 1532#1532: *3 open() "/srv/jitsi-meet/files" failed (2: No such file or directory), client: 10.11.11.21, server: _, request: "GET /files HTTP/2.0", host: "10.1.1.70"
          ==> /var/log/nginx/nginx-ews-access.log <==
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:12:39:55 -0500] "POST /EWS/Exchange.asmx HTTP/2.0" 200 2198 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:13:07:57 -0500] "POST /EWS/Exchange.asmx HTTP/2.0" 500 327 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:13:09:58 -0500] "POST /EWS/Exchange.asmx HTTP/2.0" 200 2198 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:13:36:13 -0500] "POST /EWS/Exchange.asmx HTTP/1.1" 500 365 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:13:39:58 -0500] "POST /EWS/Exchange.asmx HTTP/2.0" 200 2198 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:13:48:40 -0500] "POST /EWS/Exchange.asmx HTTP/2.0" 200 1045 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:14:09:59 -0500] "POST /EWS/Exchange.asmx HTTP/2.0" 200 2198 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:14:40:14 -0500] "POST /EWS/Exchange.asmx HTTP/2.0" 200 2198 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:09:29 -0500] "POST /EWS/Exchange.asmx HTTP/2.0" 200 2198 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:10:23 -0500] "POST /EWS/Exchange.asmx HTTP/2.0" 200 2198 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          ==> /var/log/nginx/nginx-ews-error.log <==
          ==> /var/log/nginx/nginx-mapi-access.log <==
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:09:57 -0500] "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0" 200 259 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:10:56 -0500] "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0" 200 110 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:10:56 -0500] "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0" 200 112 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:11:38 -0500] "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0" 200 182 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:12:02 -0500] "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0" 200 112 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:14:56 -0500] "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0" 200 182 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:15:48 -0500] "POST /mapi/emsmdb/?MailboxId=6679656c-6c65-2e63-6f6d-00000e000000@fyelle.com HTTP/2.0" 200 82 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:15:48 -0500] "POST /mapi/nspi/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0" 200 82 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:15:17:00 -0500] "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0" 200 189 "-" "Microsoft Office/16.0 (Windows NT 10.0; Microsoft Outlook 16.0.17126; Pro)"
          ==> /var/log/nginx/nginx-mapi-error.log <==
          2024/01/05 09:29:26 [error] 1881#1881: *272129 upstream prematurely closed connection while reading upstream, client: 142.116.39.80, server: _, request: "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0", upstream: "https://[::1]:10443/mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com", host: "mail4.domain.com"
          2024/01/05 09:29:26 [error] 1881#1881: *272129 upstream prematurely closed connection while reading upstream, client: 142.116.39.80, server: _, request: "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0", upstream: "https://127.0.0.1:10443/mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com", host: "mail4.domain.com"
          2024/01/05 09:29:26 [error] 1881#1881: *272129 connect() failed (111: Connection refused) while connecting to upstream, client: 142.116.39.80, server: _, request: "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0", upstream: "https://127.0.0.1:10443/mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com", host: "mail4.domain.com"
          2024/01/05 09:29:26 [error] 1881#1881: *272129 connect() failed (111: Connection refused) while connecting to upstream, client: 142.116.39.80, server: _, request: "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0", upstream: "https://[::1]:10443/mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com", host: "mail4.domain.com"
          2024/01/05 09:29:28 [error] 1881#1881: *272129 no live upstreams while connecting to upstream, client: 142.116.39.80, server: _, request: "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0", upstream: "https://gromoxhttp/mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com", host: "mail4.domain.com"
          2024/01/05 15:10:11 [error] 1814#1814: *5508 upstream prematurely closed connection while reading upstream, client: 142.116.39.80, server: _, request: "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0", upstream: "https://127.0.0.1:10443/mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com", host: "mail4.domain.com"
          2024/01/05 15:10:11 [error] 1814#1814: *5508 upstream prematurely closed connection while reading upstream, client: 142.116.39.80, server: _, request: "POST /mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com HTTP/2.0", upstream: "https://[::1]:10443/mapi/emsmdb/?MailboxId=6672616e-636f-6973-4066-796519000000@fyelle.com", host: "mail4.domain.com"
          ==> /var/log/nginx/nginx-meet-access.log <==
          110.239.218.106 - - [01/Jan/2024:21:16:40 -0500] "HEAD /meet HTTP/1.1" 301 0 "http://portail.domain.com" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36 OPR/102.0.0.0"
          110.239.218.106 - - [01/Jan/2024:21:16:41 -0500] "HEAD /meet/ HTTP/1.1" 200 0 "http://portail.domain.com" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36 OPR/102.0.0.0"
          110.239.222.97 - - [01/Jan/2024:21:16:46 -0500] "GET /meet HTTP/1.1" 301 173 "http://domain.com" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36 OPR/102.0.0.0"
          110.239.222.97 - - [01/Jan/2024:21:16:47 -0500] "GET /meet/ HTTP/1.1" 200 70096 "http://domain.com" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36 OPR/102.0.0.0"
          207.200.8.180 - - [03/Jan/2024:06:29:39 -0500] "GET /meet HTTP/1.1" 301 173 "https://domain.com" "LightspeedSystemsCrawler Mozilla/5.0 (Windows; U; MSIE 9.0; Windows NT 9.0; en-US)"
          207.200.8.180 - - [03/Jan/2024:06:29:39 -0500] "GET /meet/ HTTP/1.1" 200 70096 "https://domain.com" "LightspeedSystemsCrawler Mozilla/5.0 (Windows; U; MSIE 9.0; Windows NT 9.0; en-US)"
          10.11.11.21 - - [16/Jan/2024:11:57:19 -0500] "GET /meet HTTP/2.0" 301 162 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:11:57:19 -0500] "GET /meet/ HTTP/2.0" 200 20648 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:23 -0500] "GET /meet HTTP/2.0" 301 162 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:23 -0500] "GET /meet/ HTTP/2.0" 200 20648 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          ==> /var/log/nginx/nginx-meet-error.log <==
          ==> /var/log/nginx/nginx-oab-access.log <==
          142.116.39.80 - - [14/Jan/2024:12:43:37 -0500] "HEAD /OAB/oab.xml HTTP/2.0" 401 0 "-" "Microsoft BITS/7.8"
          142.116.39.80 - francois@fyelle.com [14/Jan/2024:12:43:37 -0500] "HEAD /OAB/oab.xml HTTP/2.0" 200 0 "-" "Microsoft BITS/7.8"
          142.116.39.80 - - [14/Jan/2024:12:43:37 -0500] "GET /OAB/oab.xml HTTP/2.0" 401 14 "-" "Microsoft BITS/7.8"
          142.116.39.80 - francois@fyelle.com [14/Jan/2024:12:43:37 -0500] "GET /OAB/oab.xml HTTP/2.0" 200 49 "-" "Microsoft BITS/7.8"
          142.116.39.80 - - [14/Jan/2024:14:46:32 -0500] "HEAD /OAB/oab.xml HTTP/2.0" 401 0 "-" "Microsoft BITS/7.8"
          142.116.39.80 - - [15/Jan/2024:09:07:51 -0500] "HEAD /OAB/oab.xml HTTP/2.0" 401 0 "-" "Microsoft BITS/7.8"
          142.116.39.80 - - [15/Jan/2024:09:07:53 -0500] "HEAD /OAB/oab.xml HTTP/2.0" 401 0 "-" "Microsoft BITS/7.8"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:09:07:53 -0500] "HEAD /OAB/oab.xml HTTP/2.0" 200 0 "-" "Microsoft BITS/7.8"
          142.116.39.80 - - [15/Jan/2024:09:07:53 -0500] "GET /OAB/oab.xml HTTP/2.0" 401 14 "-" "Microsoft BITS/7.8"
          142.116.39.80 - francois@fyelle.com [15/Jan/2024:09:07:53 -0500] "GET /OAB/oab.xml HTTP/2.0" 200 49 "-" "Microsoft BITS/7.8"
          ==> /var/log/nginx/nginx-oab-error.log <==
          ==> /var/log/nginx/nginx-office-access.log <==
          ==> /var/log/nginx/nginx-office-error.log <==
          ==> /var/log/nginx/nginx-rpc-access.log <==
          ==> /var/log/nginx/nginx-rpc-error.log <==
          ==> /var/log/nginx/nginx-sync-access.log <==
          10.1.1.70 - john@network.com [15/Jan/2024:15:15:13 -0500] "POST /Microsoft-Server-ActiveSync?Cmd=Settings&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1" 449 5 "-" "Android-SAMSUNG-SM-S901W/101.14"
          10.1.1.70 - john@network.com [15/Jan/2024:15:15:13 -0500] "POST /Microsoft-Server-ActiveSync?Cmd=FolderSync&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1" 449 5 "-" "Android-SAMSUNG-SM-S901W/101.14"
          10.1.1.70 - john@network.com [15/Jan/2024:15:15:30 -0500] "OPTIONS /Microsoft-Server-ActiveSync?Cmd=Options&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1" 200 5 "-" "Android-SAMSUNG-SM-S901W/101.14"
          10.1.1.70 - john@network.com [15/Jan/2024:15:15:30 -0500] "POST /Microsoft-Server-ActiveSync?Cmd=Provision&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1" 200 281 "-" "Android-SAMSUNG-SM-S901W/101.14"
          10.1.1.70 - john@network.com [15/Jan/2024:15:15:31 -0500] "POST /Microsoft-Server-ActiveSync?Cmd=Provision&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1" 200 64 "-" "Android-SAMSUNG-SM-S901W/101.14"
          10.1.1.70 - john@network.com [15/Jan/2024:15:15:32 -0500] "POST /Microsoft-Server-ActiveSync?Cmd=FolderSync&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1" 200 64 "-" "Android-SAMSUNG-SM-S901W/101.14"
          10.1.1.70 - john@network.com [15/Jan/2024:15:15:35 -0500] "POST /Microsoft-Server-ActiveSync?Cmd=Sync&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1" 200 70 "-" "Android-SAMSUNG-SM-S901W/101.14"
          10.1.1.70 - john@network.com [15/Jan/2024:15:15:35 -0500] "POST /Microsoft-Server-ActiveSync?Cmd=Ping&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1" 499 0 "-" "Android-SAMSUNG-SM-S901W/101.14"
          10.1.1.70 - john@network.com [15/Jan/2024:15:15:42 -0500] "POST /Microsoft-Server-ActiveSync?Cmd=Sync&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1" 200 71 "-" "Android-SAMSUNG-SM-S901W/101.14"
          52.96.252.101 - tommy@domain.com [15/Jan/2024:15:15:42 -0500] "POST /Microsoft-Server-ActiveSync?Cmd=Ping&User=tommy%40domain.com&DeviceId=df7c0a26ab374c779caf76bad1ddda96&DeviceType=Outlook HTTP/1.1" 200 13 "-" "Outlook-iOS-Android/1.0"
          ==> /var/log/nginx/nginx-sync-error.log <==
          2024/01/15 15:15:13 [error] 1534#1534: *134608 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 10.1.1.70, server: _, request: "OPTIONS /Microsoft-Server-ActiveSync?Cmd=Options&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-sync-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:15:13 [error] 1534#1534: *134608 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 10.1.1.70, server: _, request: "POST /Microsoft-Server-ActiveSync?Cmd=Settings&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-sync-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:15:13 [error] 1534#1534: *134608 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 10.1.1.70, server: _, request: "POST /Microsoft-Server-ActiveSync?Cmd=FolderSync&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-sync-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:15:30 [error] 1534#1534: *134608 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 10.1.1.70, server: _, request: "OPTIONS /Microsoft-Server-ActiveSync?Cmd=Options&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-sync-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:15:30 [error] 1534#1534: *134608 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 10.1.1.70, server: _, request: "POST /Microsoft-Server-ActiveSync?Cmd=Provision&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-sync-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:15:31 [error] 1534#1534: *134608 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 10.1.1.70, server: _, request: "POST /Microsoft-Server-ActiveSync?Cmd=Provision&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-sync-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:15:32 [error] 1534#1534: *134608 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 10.1.1.70, server: _, request: "POST /Microsoft-Server-ActiveSync?Cmd=FolderSync&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-sync-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:15:35 [error] 1534#1534: *134608 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 10.1.1.70, server: _, request: "POST /Microsoft-Server-ActiveSync?Cmd=Sync&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-sync-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:15:42 [error] 1534#1534: *134608 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 10.1.1.70, server: _, request: "POST /Microsoft-Server-ActiveSync?Cmd=Sync&User=jean%40domain.com&DeviceId=SEC19C2158ABC31A&DeviceType=SamsungDevice HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-sync-fpm.sock:", host: "mail4.domain.com"
          2024/01/15 15:15:42 [error] 1534#1534: *134627 FastCGI sent in stderr: "Passing INI directive through FastCGI: unable to set 'zend.exception_string_param_max_len'" while reading response header from upstream, client: 52.96.252.101, server: _, request: "POST /Microsoft-Server-ActiveSync?Cmd=Ping&User=tommy%40domain.com&DeviceId=df7c0a26ab374c779caf76bad1ddda96&DeviceType=Outlook HTTP/1.1", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-sync-fpm.sock:", host: "mail4.domain.com"
          ==> /var/log/nginx/nginx-web-access.log <==
          10.11.11.21 - - [16/Jan/2024:20:10:14 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 200 4054 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:14 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 200 144 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:14 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 200 154 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:14 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 200 63 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:15 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 200 362 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:17 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 200 1141 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:17 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 200 114 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:18 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 200 4054 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:10:43 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 200 70 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          10.11.11.21 - - [16/Jan/2024:20:11:14 -0500] "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0" 200 70 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
          ==> /var/log/nginx/nginx-web-error.log <==
          #1 /usr/share/grommunio-web/grommunio.php(147): JSONRequest->execute()
          #2 {main}
          thrown in /usr/share/grommunio-web/plugins/files/php/modules/class.hierarchylistmodule.php on line 79" while reading response header from upstream, client: 10.11.11.21, server: _, request: "POST /web/grommunio.php?subsystem=webapp_1705423938534 HTTP/2.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-web-fpm.sock:", host: "10.1.1.70"
          2024/01/16 20:10:13 [error] 1532#1532: *3 FastCGI sent in stderr: "PHP message: Failed to open store. john@network.com requested 0000000038a1bb1005e5101aa1bb08002b2a56c20000454d534d44422e444c4c00000000000000001b55fa20aa6611cd9bc800aa002fc45a0c0000006a65616e40616d657269636d656469612e636f6d002f6f3d6936326532663338652f6f753d45786368616e67652041646d696e6973747261746976652047726f7570202846594449424f484632335350444c54292f636e3d526563697069656e74732f636e3d313130303030303030663030303030302d6a65616e00e94632f43c00000002000000100000006a00650061006e00400061006d0065007200690063006d0065006400690061002e0063006f006d0000000000PHP message: Failed to open store. john@network.com requested 0000000038a1bb1005e5101aa1bb08002b2a56c200006d737073742e646c6c00000000004e495441f9bfb80100aa0037d96e0000000043003a005c00550073006500720073005c006a00650061006e005c0041007000700044006100740061005c004c006f00630061006c005c004d006900630072006f0073006f00660074005c004f00750074006c006f006f006b005c0049006e007400650072006e00650074002000430061006c0065006e00640061007200200053007500620073006300720069007000740069006f006e00730020002d0020004a00650061006e002e007000730074000000" while reading response header from upstream, client: 10.11.11.21, server: _, request: "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-web-fpm.sock:", host: "10.1.1.70"
          2024/01/16 20:10:14 [error] 1532#1532: *3 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Error: Call to undefined method Sabre\HTTP\ClientHttpException::getTitle() in /usr/share/grommunio-web/plugins/files/php/modules/class.hierarchylistmodule.php:79
          Stack trace:
          #0 /usr/share/grommunio-web/server/includes/core/class.jsonrequest.php(60): HierarchyListModule->execute()
          #2 {main}
          thrown in /usr/share/grommunio-web/plugins/files/php/modules/class.hierarchylistmodule.php on line 79" while reading response header from upstream, client: 10.11.11.21, server: _, request: "POST /web/grommunio.php?subsystem=webapp_1705453706733 HTTP/2.0", upstream: "fastcgi://unix:/run/php-fpm/php-grommunio-web-fpm.sock:", host: "10.1.1.70"
          The directory /var/log/grommunio/ was removed some time ago, all nginx logs should be placed in /var/log/nginx/. I assume you have an old configuration file that points to /var/log/grommunio/ instead of /var/log/nginx/. Try to find this old configuration file and replace or repair it. Did you follow step 21. to migrate outdated configuration files?
          This is weird. I don't understand why my system did not follow all changes. Why my files do not log at the right place? I don't know. I think that you guys should know better than me. I did install this system on october 2021 and I Never did a thing in exception of running zypper up.
          I'm propably stupid, but I thought that zypper up was the right thing to run to keep up to date.
          Your step 21 are not easy. I compared all files from what the find command found.
          find / -print | egrep '*.rpmnew'
          /var/lib/grommunio-files/config/config.php.rpmnew
          /etc/grommunio-chat/config.json.rpmnew
          /etc/postfix/main.cf.rpmnew
          /etc/postfix/master.cf.rpmnew
          /etc/postfix/transport.rpmnew
          /etc/systemd/timesyncd.conf.rpmnew
          /etc/zypp/zypp.conf.rpmnew
          /etc/crontab.rpmnew
          1- Folks, am I the only one who's trying to migrate my system to the last verison?
          2- Is it the only precedure availabe to show us How to migrate to the last version?
            Try to find the config file that points to /var/log/grommunio/ and repair this paths:
            grep -R "/var/log/grommunio/" /etc/*
            bunker Your step 21 are not easy.
            New versions of programs may have new parameter any you have to adjust the configuration files manually.
