IMAP broken again for specific client application
gromox-2.18-29-gc0e36e279
- Edited
No logs, no help. imaptests run with all green lights, that does not mean there might not still be an issue (as mentioned thunderbird works well, alpine, macOS and even outlook IMAP too (not that anyone wants mac or OL on IMAP). Providing some more information from your side is strongly encouraged if you expect any help.
You did follow this, right? https://community.grommunio.com/d/1323-grommunio-218-release/2
gromox-2.18-49-g3f74a39a8
- Edited
If you have IMAP problems, try to add two settings to /etc/gromox/imap.cfg
context_num = 500
context_max_mem = 4M
And restart IMAP: systemctl restart gromox-imap
With version 2.18.54.50cb286 from today Mailstore Archiv is working again
rg
Christian
Yes, works again. The mmv command did not change anything, that was not the issue, I also did not change anything in the configuration.
