Grommunio seems to ship an updated version of sqlite that breaks dnf.
Anyone else affected?
bye
Daniel
    daniel just checked, and yes - DNF is broken on my machine after installing a version of SQLite from Grommunio. The offending package appears to be sqlite-libs. If I append --exclude=sqlite-libs then DNF commands succeed and I can install updates.
    @Andrew Yeah, I downgraded, too and it seems to work.
    I was afraid that the sqlite error above (missing CONCAT function) will be reintroduced again, but gromox still seems to use the old statements.
    Yesterday I created an issue on Github, if you'd like to follow:
    https://github.com/grommunio/gromox/issues/118
    5 days later
    Looks like the SQLite packages have been pulled from the Grommunio repo, but the current version of grommunio-index is dependent on them so dnf upgrade fails unless that package is excluded. I reverted back to the RHEL SQLite packages but started getting CONCAT errors and a crashing index, so I've went back to my workaround of compiling my own version of SQLite libraries, and applied the override to both the gromox-http and grommunio-index services.
    11 days later
    Installed latest updates. Seems like it's still breaking NGINX, and grommunio-index won't update because of a broken dependency on the deleted sqlite-libs package.
    Looks like the grommunio-index dependency is now fixed. I removed my custom SQLite override on the gromox-http and grommunio-index services yesterday and haven't had any issues so far.
    11 days later
    SQLite issues seem to be resolved, but the NGINX config is still getting mangled by updates
      Andrew but the NGINX config is still getting mangled by updates
      Please explain (with examples) what you mean with: but the NGINX config is still getting mangled by updates ?
        Andrew
        The only one outstanding I believe now is the rogue load_module lines getting added to NGINX. I updated again last night and they got added back in, breaking NGINX once more. Deleting these lines (they're trying to load the modules from the original /usr/share/nginx/modules location but Grommunio moved them to /usr/lib64/nginx/modules) fixes it temporarily, but every time an update gets installs it re-adds the offending lines and breaks NGINX again.
        > load_module modules/ngx_http_brotli_static_module.so;
        > load_module modules/ngx_http_brotli_filter_module.so;
        > load_module modules/ngx_http_vhost_traffic_status_module.so;
        i believe they mean those which of course get reset by the packages config files.
        can't you set some hook in DNF? to run like a sed over a file if it's beein updated by a package?
        Are this modules installed on your system? I guess not and nginx refuses to load about missing modules.
        If the grommunio developers wants theses modules, the system needs the modules. Try to install these modules and see what's happen?
          WalterH it's referenced a few times above. Every time an update gets installs it adds the following lines to the NGINX config that are referencing the wrong location, which causes NGINX to crash on start-up. Removing the offending lines resolves the issue temporarily, but every time a grommunio-common update installs it breaks NGINX again.
          @daniel created an issue on GitHub for it: https://github.com/grommunio/gromox/issues/121
          WalterH messages crossed in the ether.
          The modules are installed and working, but during a previous update Grommunio moved them from /usr/share/nginx/modules to /usr/lib64/nginx/modules. They are correctly loading from /usr/lib64/nginx/modules, but the rogue lines that keep getting added to NGINX config are trying to load them from the old location as well, where they do not exist.
          Recreating the problem, showing the problematic load_module lines coming from grommunio-common:
          [user@host ~]$ sudo head /etc/nginx/nginx.conf
          # For more information on configuration, see:
          #   * Official English Documentation: http://nginx.org/en/docs/
          #   * Official Russian Documentation: http://nginx.org/ru/docs/
          user nginx;
          worker_processes auto;
          error_log /var/log/nginx/error.log;
          pid /run/nginx.pid;
          [user@host ~]$ sudo dnf reinstall grommunio-common -y
          Updating Subscription Management repositories.
          Last metadata expiration check: 2:27:50 ago on Tue 28 Jan 2025 09:29:54 GMT.
          Dependencies resolved.
           Package                                           Architecture                            Version                                          Repository                                  Size
          Reinstalling:
           grommunio-common                                  x86_64                                  26.a6f127d-44.3                                  grommunio                                   14 k
          Transaction Summary
          Total download size: 14 k
          Installed size: 8.6 k
          Downloading Packages:
          grommunio-common-26.a6f127d-44.3.x86_64.rpm        80 kB/s |  14 kB     00:00
          Total        78 kB/s |  14 kB     00:00
          Running transaction check
          Transaction check succeeded.
          Running transaction test
          Transaction test succeeded.
          Running transaction
            Preparing        :        1/1
            Reinstalling     : grommunio-common-26.a6f127d-44.3.x86_64        1/2
            Running scriptlet: grommunio-common-26.a6f127d-44.3.x86_64        1/2
            Cleanup          : grommunio-common-26.a6f127d-44.3.x86_64        2/2
            Verifying        : grommunio-common-26.a6f127d-44.3.x86_64        1/2
            Verifying        : grommunio-common-26.a6f127d-44.3.x86_64        2/2
          Installed products updated.
          Reinstalled:
          Complete!
          user nginx;
          [user@host ~]$
          The modules themselves are getting loaded fine from their new locations. Grommunio added config files in /usr/share/nginx/modules that take care of it when they moved the modules:
          [user@host ~]$ cat /usr/share/nginx/modules/mod-brotli.conf
          load_module "/usr/lib64/nginx/modules/ngx_http_brotli_filter_module.so";
          load_module "/usr/lib64/nginx/modules/ngx_http_brotli_static_module.so";
          [user@host ~]$ cat /usr/share/nginx/modules/mod-vhost-traffic-status.conf
          load_module "/usr/lib64/nginx/modules/ngx_http_vhost_traffic_status_module.so";
          It's just the load_module lines getting added to nginx.conf directly that cause the problem.
          I looked in some of the packages in EL9 repository, unfortunately I did not find the nginx.conf file in these packages.
          I searched in: gromox, grommunio-dav, grommunio-common, grommunio-admin-web, grommunio-admin-common, grommunio-web, grommunio-sync and grommunio-common but did not find the nginx.conf.
          Do you know which package overwrites the nginx.conf file?
            WalterH it looks to be grommunio-common.
            In my last reply to this thread I've copy-pasted an example of the terminal output from checking nginx.conf (no load_module lines in the "head" output at this point), reinstalling grommunio-common, then re-checking nginx.conf. After installing grommunio-common the offending lines reappear.
            Interestingly, in grommunio-common-26.a6f127d-44.3.x86_64.rpm there is no nginx.conf copied to /etc/nginx. The question is, are there any scripts running that might modify nginx.conf or restore an old backup after installing grommunio-common?
            Looking at the spec file for grommunio-common using rpmrebuild, this part looks like the issue:
            if [ -f "/etc/nginx/nginx.conf" ]; then
                    if ! grep -q "^load_module modules/ngx_http_vhost_traffic_status_module.so;" "/etc/nginx/nginx.conf"; then
                            sed -i 's/\(worker_processes.*\)/\1\nload_module modules\/ngx_http_vhost_traffic_status_module.so;/' "/etc/nginx/nginx.conf"
                    fi
                if ! grep -q "^load_module modules/ngx_http_brotli_filter_module.so;" "/etc/nginx/nginx.conf"; then
                            sed -i 's/\(worker_processes.*\)/\1\nload_module modules\/ngx_http_brotli_filter_module.so;/' "/etc/nginx/nginx.conf"
                    fi
                    if ! grep -q "^load_module modules/ngx_http_brotli_static_module.so;" "/etc/nginx/nginx.conf"; then
                            sed -i 's/\(worker_processes.*\)/\1\nload_module modules\/ngx_http_brotli_static_module.so;/' "/etc/nginx/nginx.conf"
                    fi
            fi
            This was looking at the grommunio-common-26.a6f127d-44.3.x86_64.rpm package from the repo using rpmrebuild -e -p grommunio-common-26.a6f127d-44.3.x86_64.rpm
            OK, it is a script.
            Unfortunately I do not have a RHEL system to test.
            12 days later
