• SolvedFixed
  • Email Abholung funktioniert, keine Postfachzustellung
meanwhile i have a few hundred mails in the mail queue. Is there a way to downgrade the gromox version using zypper?
Why not 2.38.17.gdde284b-lp155.20.1 ?
  • OlKl replied to this.
    On my produktiv system I make a clone of the VM before each Update so to step back is a thing of seconds. Therefore I have two results above one of produktiv one of test system.
    Andy
    2.38.14.x330426e-lp155.8.1 was the only older version i found to be available for download.
    I have now seen that too. There is always a strange order on the download server.
    should be solved with gromox-2.38-38-g8b5eeeaf1
    I confirm, with the current versions is solved.
    Version     : 2.38.38.g8b5eeea
    Release     : lp155.30.1
    grommunio-admin-api-1.16.11.23c560a-lp155.125.1.noarch
    grommunio-admin-common-38.f4553bd-lp155.24.1.noarch
    grommunio-admin-web-3.1.0.46.f86103e-lp155.113.1.noarch
    grommunio-antispam-3.10.2-lp155.1.3.x86_64
    grommunio-archive-1.3.13.g137.d1b0df1b-lp155.9.44.x86_64
    grommunio-chat-9.8.1-lp155.1.1.x86_64
    grommunio-common-26.a6f127d-lp155.43.1.x86_64
    grommunio-cui-1.0.273.9a6e6de-lp155.74.1.noarch
    grommunio-dav-1.3.74.94260cb-lp155.3.1.noarch
    grommunio-dbconf-1.1.1.da20a46-lp155.5.1.x86_64
    grommunio-error-pages-1.0.10.bb2df37-lp155.10.1.noarch
    grommunio-files-27.1.10-lp155.2.1.noarch
    grommunio-imapsync-2.264-lp155.1.1.noarch
    grommunio-index-1.2.1.g6b167a2-lp155.85.1.x86_64
    grommunio-office-7.4.1-lp155.6.18.x86_64
    grommunio-office-fonts-7.4.1-lp155.6.18.noarch
    grommunio-release-2023.11.3-lp155.2.1.x86_64
    grommunio-setup-1.1.9.718dcd5-lp155.57.1.noarch
    grommunio-sync-2.0.141.9aa611d-lp155.179.1.noarch
    grommunio-web-3.9.207.ga6f0321b-lp155.166.1.noarch
    gromox-2.38.38.g8b5eeea-lp155.30.1.x86_64
    gromox-debuginfo-2.38.38.g8b5eeea-lp155.30.1.x86_64
    gromox-debugsource-2.38.38.g8b5eeea-lp155.30.1.x86_64
    grub2-theme-grommunio-1-lp155.20.1.noarch
    jitsi-meet-branding-grommunio-2.0.6726-lp155.5.1.noarch
    patterns-grommunio-1-lp155.9.1.x86_64
    plymouth-theme-grommunio-1-lp155.20.1.noarch
    systemd-coredump-grommunio-1-lp155.3.1.noarch
    systemd-presets-branding-grommunio-2024.06-lp155.2.1.noarch
    system-user-grommunio-10-lp155.2.1.noarch
    system-user-gromox-9-lp155.5.1.noarch
    localhost:~ #
    But some warnings are still open:
    Repository-Daten werden geladen...
    Warnung: Metadaten von Repository 'debug-update' seit 2024-12-20 15:11:38 CET abgelaufen.
    Warnung: Metadaten von Repository 'update' seit 2024-12-20 15:11:15 CET abgelaufen.
        Warnung: Die Metadaten des Repositorys sind abgelaufen: Prüfen Sie, ob 'autorefresh' aktiviert
        ist (zypper lr). Aktualisieren Sie andernfalls das Repository manuell (zypper ref). Wenn das
        Problem weiterhin besteht, verwenden Sie möglicherweise einen defekten Spiegel oder der Server
        hat die Unterstützung für das Repository eingestellt.
      Andy Warnung: Die Metadaten ...
      zypper ref -f
      zypper dup
      sollte das reparieren.
      Nach wie vor leider nicht. Mein Eindruck ist, dass wohl Eingriffe oder Freigaben erforderlich sind.
      localhost:~ # zypper --verbose ref -f && zypper --verbose dup
      Ausführlichkeitsgrad: 2
      Ziel wird initialisiert
      Angegebene Repositorys:
      Aktualisieren der Rohmetadaten erzwingen
      Abrufen: repomd.xml.asc .......................................................................................................[fertig (827 B/s)]
      Abrufen: repomd.xml.key .....................................................................................................[fertig (1,7 KiB/s)]
      Abrufen: repomd.xml .....................................................................................................................[fertig]
        Repository:               backports-debug-update
        Schlüssel-Fingerabdruck:  F044 C2C5 07A1 262B 538A AADD 8A49 EB03 25DB 7AE0
        Name des Schlüssels:      openSUSE:Backports OBS Project <openSUSE:Backports@build.opensuse.org>
        Schlüsselalgorithmus:     RSA 4096
        Schlüssel erstellt:       Mi 10 Mai 2023 16:46:12 CEST
        Ablauf des Schlüssels:    So 09 Mai 2027 16:46:12 CEST
        RPM-Name:                 gpg-pubkey-25db7ae0-645bae34
      Abrufen: e08f92e8fbceddf73a32f9ebaebee68834ad778419c57ec7b97ead0bccbaa072-primary.xml.gz ................................................[fertig]
      Abrufen: 5afc6cb78c11733eb7ae0cd9dfefc5a37fba3d6530ec285484cf419be9bc7e84-suseinfo.xml.gz ...............................................[fertig]
      Metadaten von Repository 'backports-debug-update' abrufen ...............................................................................[fertig]
      Erstellen des Repository-Cache erzwingen
      Cache für Repository 'backports-debug-update' erzeugen ..................................................................................[fertig]
        Repository:               backports-update
      Abrufen: 6ab4a71330a3b8d836812b99f6e9fafd528c1ca772f5ec604be54f3758cd77fd-deltainfo.xml.gz ................................[fertig (462,0 KiB/s)]
      Abrufen: c66c450f80c444194e0491132947c90208a00a6d1a22c42c69eaba5b3a58ce41-primary.xml.gz ...................................[fertig (11,7 MiB/s)]
      Abrufen: 51f079a07f8713807d68b62af1addb0a15ee297c602a979dee4df7c3fef14f7e-updateinfo.xml.gz .............................................[fertig]
      Metadaten von Repository 'backports-update' abrufen .....................................................................................[fertig]
      Cache für Repository 'backports-update' erzeugen ........................................................................................[fertig]
      Abrufen: media ................................................................................................................[fertig (137 B/s)]
      Abrufen: repomd.xml.key .....................................................................................................[fertig (1,6 KiB/s)]
        Repository:               base
        Schlüssel-Fingerabdruck:  AD48 5664 E901 B867 051A B15F 35A2 F86E 29B7 00A4
        Name des Schlüssels:      openSUSE Project Signing Key <opensuse@opensuse.org>
        Schlüssel erstellt:       Mo 20 Jun 2022 16:03:14 CEST
        Ablauf des Schlüssels:    Fr 19 Jun 2026 16:03:14 CEST
        RPM-Name:                 gpg-pubkey-29b700a4-62b07e22
      Abrufen: d0aae74c050dca8d30fbccd949a136d8ed209eccf8fdf435ac8c1d739271d8e7-appdata.xml.gz ...................................[fertig (18,7 MiB/s)]
      Abrufen: e4ead9598bf02220a39abbb166bd58f398e8159bd140f26ebf5623ddc27537a5-appdata-icons.tar.gz .............................[fertig (23,7 MiB/s)]
      Abrufen: 37e4f0e207c01e1b48999f8937b543332c264557169087162bbad9c715101f6d-license.tar.gz ................................................[fertig]
      Abrufen: 2aa1fa637f7b84d8329ac01fbe3369c2c0794e8c9e9e6203b7ddadb91dbf8700-primary.xml.gz ...................................[fertig (24,8 MiB/s)]
      Abrufen: f87dc4a7c757935d471170b582e2ea1912d22b52618f0a95b1f0d3ed42f8c421-susedata.xml.gz ..................................[fertig (12,2 MiB/s)]
      Abrufen: b6145b692a6f3cdf6cbea174c8f9653af1e0dfeb667b248efab23e761489f300-susedata.de.xml.gz ................................[fertig (1,7 MiB/s)]
      Metadaten von Repository 'base' abrufen .................................................................................................[fertig]
      Cache für Repository 'base' erzeugen ....................................................................................................[fertig]
      Abrufen: media ................................................................................................................[fertig (143 B/s)]
        Repository:               debug
      Abrufen: 4ad23d6099bb3e5659073b4ce7e395aa2295d09f818708221400c5788a80daad-appdata.xml.gz ................................................[fertig]
      Abrufen: 60477ac695631209feb8de4c83e6e524a98e576f040b2593351b66203e8e96ce-primary.xml.gz ....................................[fertig (3,5 MiB/s)]
      Abrufen: 91ac27ca4ea8c04f7950e4280ea460a242048e1c827adf89aa3f0e63d6eb7d5d-susedata.xml.gz ...................................[fertig (9,9 MiB/s)]
      Abrufen: a5b9125090f4487980e3bf94d469ae3a3c5c6e47016b18a0ddf26e9a7106bce7-susedata.de.xml.gz ............................................[fertig]
      Metadaten von Repository 'debug' abrufen ................................................................................................[fertig]
      Cache für Repository 'debug' erzeugen ...................................................................................................[fertig]
        Repository:               debug-update
      Abrufen: 3725b4509e1db412a40f862d31f94cf9cb7f712e4e3b0082c388b925d23d86ba-primary.xml.gz ................................................[fertig]
      Metadaten von Repository 'debug-update' abrufen .........................................................................................[fertig]
      Cache für Repository 'debug-update' erzeugen ............................................................................................[fertig]
      Abrufen: repomd.xml.asc .......................................................................................................[fertig (833 B/s)]
      Abrufen: repomd.xml.key .....................................................................................................[fertig (2,1 KiB/s)]
        Repository:               grommunio
        Schlüssel-Fingerabdruck:  87B1 B28E 1E1F 6721 798C D1CD F448 DE9B 1BE2 31D9
        Name des Schlüssels:      grommunio Repository Signing Key <info@grommunio.com>
        Schlüssel erstellt:       So 15 Mai 2022 22:26:10 CEST
        Ablauf des Schlüssels:    Fr 14 Mai 2027 22:26:10 CEST
        Unterschlüssel:           1629B6CB7C0F8CFC 2022-05-15 [läuft ab: 2027-05-14]
        RPM-Name:                 gpg-pubkey-1be231d9-628161e2
      Abrufen: 654815ec49a9ecdbaa02c0572049252c867a7a685b9e61e16b2a443051efbbde-primary.xml.gz ................................................[fertig]
      Metadaten von Repository 'grommunio' abrufen ............................................................................................[fertig]
      Cache für Repository 'grommunio' erzeugen ...............................................................................................[fertig]
      Abrufen: repomd.xml.asc .......................................................................................................[fertig (481 B/s)]
      Abrufen: repomd.xml.key .......................................................................................................[fertig (969 B/s)]
        Repository:               sle-debug-update
        Schlüssel-Fingerabdruck:  FEAB 5025 39D8 46DB 2C09 61CA 70AF 9E81 39DB 7C82
        Name des Schlüssels:      SuSE Package Signing Key <build@suse.de>
        Schlüsselalgorithmus:     RSA 2048
        Schlüssel erstellt:       Mi 21 Aug 2024 14:10:02 CEST
        Ablauf des Schlüssels:    Mo 02 Okt 2028 14:10:02 CEST
        RPM-Name:                 gpg-pubkey-39db7c82-66c5d91a
      Abrufen: e332db287f3dd13704d7575b02b3c4c7d00f59149712362211cdcd3e316f49f9-primary.xml.gz ...................................[fertig (12,5 MiB/s)]
      Metadaten von Repository 'sle-debug-update' abrufen .....................................................................................[fertig]
      Cache für Repository 'sle-debug-update' erzeugen ........................................................................................[fertig]
        Repository:               sle-update
      Abrufen: 71b7f2d40402c5ae8f73fe465c2254e2df319eecbf44c883aae478b43697833e-deltainfo.xml.gz ..................................[fertig (9,1 MiB/s)]
      Abrufen: d954838e5e68bdc07d2a897fc0af87426ee94e376bd6ae43f7e801fac27f53f5-primary.xml.gz ...................................[fertig (13,3 MiB/s)]
      Abrufen: 907f392bbef74dd088892b587d78c56b2a2e959d1a5db305de942bbdfea9cfa2-susedata.xml.gz ...............................................[fertig]
      Abrufen: 7e5c3d5b48c79b588cc018433c1cf0044d08e796bb7b37e9f5498d8685441b0a-updateinfo.xml.gz .................................[fertig (5,6 MiB/s)]
      Metadaten von Repository 'sle-update' abrufen ...........................................................................................[fertig]
      Cache für Repository 'sle-update' erzeugen ..............................................................................................[fertig]
      Abrufen: media ................................................................................................................[fertig (144 B/s)]
        Repository:               src
      Abrufen: afa747fd647b741841ab0077f489065f26008828ef24fbda42cbc35d2cb3be44-primary.xml.gz ....................................[fertig (6,0 MiB/s)]
      Abrufen: 72c8ea53136b30426688f354eb7b057e65dfd6f90f1ce4529fbac91c76514634-susedata.xml.gz ...............................................[fertig]
      Abrufen: 64233f331150f64cee74d80717899dd362eddf6517ae80ea03ac96460ab6fb3c-susedata.de.xml.gz ............................................[fertig]
      Metadaten von Repository 'src' abrufen ..................................................................................................[fertig]
      Cache für Repository 'src' erzeugen .....................................................................................................[fertig]
        Repository:               update
      Abrufen: c67cf63f660bb8470946b4ed97b7a230d21a302338a684df6318a76f7eb9e884-deltainfo.xml.gz ..............................................[fertig]
      Abrufen: bbaf5897eb950f9b2ca960be96f36bd78f0260b75ceeca221f703fe2170d3929-primary.xml.gz ..................................[fertig (436,0 KiB/s)]
      Abrufen: a635ed1adaaf74cb2299401ca81b695fbbb2287e71191033e88f93e3d3c08ce2-updateinfo.xml.gz .............................................[fertig]
      Metadaten von Repository 'update' abrufen ...............................................................................................[fertig]
      Cache für Repository 'update' erzeugen ..................................................................................................[fertig]
      Alle Repositorys wurden aktualisiert.
      Es wird überprüft, ob die Metadaten für backports-update aktualisiert werden müssen
      Es wird überprüft, ob die Metadaten für base aktualisiert werden müssen
      Es wird überprüft, ob die Metadaten für grommunio aktualisiert werden müssen
      Es wird überprüft, ob die Metadaten für sle-update aktualisiert werden müssen
      Es wird überprüft, ob die Metadaten für update aktualisiert werden müssen
      Installierte Pakete werden gelesen...
      Warnung: Sie sind im Begriff, eine Distributionsaktualisierung mit allen aktivierten Repositorys durchzuführen. Vergewissern Sie sich, dass diese Repositorys kompatibel sind, bevor Sie fortfahren. Weitere Informationen zu diesem Kommando finden Sie unter 'man zypper'.
      Distributions-Aktualisierungen werden verarbeitet...
      Auflösung erzwingen: Nein
      Aktualisierung wird berechnet...
      Keine auszuführenden Aktionen.
      localhost:~ #
      bleiben die Mails in den Mailqueues hängen?
      mailq
      gromox-mailq
      Nein, alle Emails kommen an.
      localhost:~ # mailq
      Mail queue is empty
      localhost:~ # gromox-mailq
      #Qid    date                  msg_size        Fid  Sender Recipient
      localhost:~ #
      Die Basic-Fehlersuche mit systemctl --failed und journalctl -f wurde schon gemacht?
      Wie folgt, wobei ich inhaltlich nichts dazu sagen kann:
      localhost:~ # systemctl --failed
        UNIT LOAD ACTIVE SUB DESCRIPTION
      0 loaded units listed.
      localhost:~ # journalctl -f
      Dez 26 09:31:33 localhost systemd[15749]: Reached target Main User Target.
      Dez 26 09:31:33 localhost systemd[15749]: Startup finished in 183ms.
      Dez 26 09:31:33 localhost systemd[1]: Started User Manager for UID 0.
      Dez 26 09:31:33 localhost systemd[1]: Started Session 50 of User root.
      Dez 26 09:31:33 localhost sshd[15743]: pam_unix(sshd:session): session opened for user root by (uid=0)
      Dez 26 09:31:33 localhost systemd[1]: grommunio-files-cron.service: Deactivated successfully.
      Dez 26 09:31:36 localhost jvb.sh[1901]: Dez. 26, 2024 9:31:36 VORM. org.jitsi.utils.logging2.LoggerImpl log
      Dez 26 09:31:36 localhost jvb.sh[1901]: INFORMATION: Running expire()
      Dez 26 09:31:36 localhost jvb.sh[1901]: INFORMATION: Performed a successful health check in PT0.00001S. Sticky failure: false
      Dez 26 09:32:17 localhost rspamd[2362]: (controller) <5t8s4f>; map; http_map_finish: data is not modified for server sa-update.surbl.org, next ch        eck at Thu, 26 Dec 2024 08:37:17 GMT (timer based)
      Dez 26 09:32:36 localhost jvb.sh[1901]: Dez. 26, 2024 9:32:36 VORM. org.jitsi.utils.logging2.LoggerImpl log
      Dez 26 09:32:36 localhost jvb.sh[1901]: INFORMATION: Running expire()
      Dez 26 09:32:36 localhost jvb.sh[1901]: INFORMATION: Performed a successful health check in PT0.000009S. Sticky failure: false
      Dez 26 09:33:36 localhost jvb.sh[1901]: Dez. 26, 2024 9:33:36 VORM. org.jitsi.utils.logging2.LoggerImpl log
      Dez 26 09:33:36 localhost jvb.sh[1901]: INFORMATION: Running expire()
      Dez 26 09:33:36 localhost jvb.sh[1901]: INFORMATION: Performed a successful health check in PT0.000009S. Sticky failure: false
      Dez 26 09:34:02 localhost rspamd[2362]: (controller) <37h8g3>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for list.dnswl.o        rg while 'no records with this name' was expected when querying for '1.0.0.127.list.dnswl.org'(likely DNS spoofing or BL internal issues)
      Dez 26 09:34:36 localhost jvb.sh[1901]: Dez. 26, 2024 9:34:36 VORM. org.jitsi.utils.logging2.LoggerImpl log
      Dez 26 09:34:36 localhost jvb.sh[1901]: INFORMATION: Running expire()
      Dez 26 09:34:36 localhost jvb.sh[1901]: INFORMATION: Performed a successful health check in PT0.000011S. Sticky failure: false
      Dez 26 09:35:00 localhost grommunio-chat[1899]: {"timestamp":"2024-12-26 09:35:00.005 +01:00","level":"error","msg":"Failed to get system bot","caller":"app/post.go:2216","component":"post_reminders","error":"GetSystemBot: List of admins is empty."}
      Dez 26 09:35:01 localhost systemd[1]: Created slice User Slice of UID 460.
      Dez 26 09:35:01 localhost systemd[1]: Starting User Runtime Directory /run/user/460...
      Dez 26 09:35:01 localhost systemd[1]: Finished User Runtime Directory /run/user/460.
      Dez 26 09:35:01 localhost systemd[1]: Starting User Manager for UID 460...
      Dez 26 09:35:01 localhost (systemd)[16184]: pam_unix(systemd-user:session): session opened for user groarchive by (uid=0)
      Dez 26 09:35:01 localhost systemd[16184]: Queued start job for default target Main User Target.
      Dez 26 09:35:01 localhost systemd[16184]: Created slice User Application Slice.
      Dez 26 09:35:01 localhost systemd[16184]: Started Daily Cleanup of User's Temporary Directories.
      Dez 26 09:35:01 localhost systemd[16184]: Reached target Paths.
      Dez 26 09:35:01 localhost systemd[16184]: Reached target Timers.
      Dez 26 09:35:01 localhost systemd[16184]: Starting D-Bus User Message Bus Socket...
      Dez 26 09:35:01 localhost systemd[16184]: Starting Create User's Volatile Files and Directories...
      Dez 26 09:35:01 localhost systemd[16184]: Finished Create User's Volatile Files and Directories.
      Dez 26 09:35:01 localhost systemd[16184]: Listening on D-Bus User Message Bus Socket.
      Dez 26 09:35:01 localhost systemd[16184]: Reached target Sockets.
      Dez 26 09:35:01 localhost systemd[16184]: Reached target Basic System.
      Dez 26 09:35:01 localhost systemd[16184]: Reached target Main User Target.
      Dez 26 09:35:01 localhost systemd[16184]: Startup finished in 133ms.
      Dez 26 09:35:01 localhost systemd[1]: Started User Manager for UID 460.
      Dez 26 09:35:01 localhost systemd[1]: Started Session c141 of User groarchive.
      Dez 26 09:35:01 localhost systemd[1]: Started Session c142 of User groarchive.
      Dez 26 09:35:01 localhost systemd[1]: Started Session c143 of User groarchive.
      Dez 26 09:35:01 localhost cron[16181]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
      Dez 26 09:35:01 localhost CRON[16192]: (groarchive) CMD (/usr/bin/find /usr/share/grommunio-archive/archive/tmp -type f -name i.\* -exec rm -f {} \;)
      Dez 26 09:35:01 localhost cron[16180]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
      Dez 26 09:35:01 localhost CRON[16193]: (groarchive) CMD (/usr/bin/find /var/lib/grommunio-archive/error -type f | wc -l > /var/lib/grommunio-archive/stat/error)
      Dez 26 09:35:01 localhost CRON[16181]: (groarchive) CMDEND (/usr/bin/find /usr/share/grommunio-archive/archive/tmp -type f -name i.\* -exec rm -f {} \;)
      Dez 26 09:35:01 localhost cron[16182]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
      Dez 26 09:35:01 localhost CRON[16181]: pam_unix(crond:session): session closed for user groarchive
      Dez 26 09:35:01 localhost CRON[16180]: (groarchive) CMDEND (/usr/bin/find /var/lib/grommunio-archive/error -type f | wc -l > /var/lib/grommunio-archive/stat/error)
      Dez 26 09:35:01 localhost CRON[16196]: (groarchive) CMD (/usr/lib/grommunio-archive/indexer.delta.sh)
      Dez 26 09:35:01 localhost systemd[1]: session-c141.scope: Deactivated successfully.
      Dez 26 09:35:01 localhost CRON[16180]: pam_unix(crond:session): session closed for user groarchive
      Dez 26 09:35:01 localhost systemd[1]: session-c142.scope: Deactivated successfully.
      Dez 26 09:35:01 localhost groarchive[16200]: INDEXER INFO: indexing delta1 started
      Dez 26 09:35:01 localhost searchd[1926]: caught SIGHUP (seamless=1, in queue=1)
      Dez 26 09:35:01 localhost groarchive[16203]: INDEXER INFO: indexing delta1 finished
      Dez 26 09:35:01 localhost searchd[1926]: rotating index 'delta1': started
      Dez 26 09:35:01 localhost searchd[1926]: rotating index 'delta1': success
      Dez 26 09:35:01 localhost searchd[1926]: rotating index: all indexes done
      Dez 26 09:35:06 localhost groarchive[16216]: INDEXER INFO: merging delta to dailydelta started
      Dez 26 09:35:07 localhost searchd[1926]: caught SIGHUP (seamless=1, in queue=1)
      Dez 26 09:35:07 localhost searchd[1926]: rotating index 'dailydelta1': started
      Dez 26 09:35:07 localhost groarchive[16219]: INDEXER INFO: merging delta to dailydelta finished
      Dez 26 09:35:07 localhost CRON[16182]: (groarchive) CMDEND (/usr/lib/grommunio-archive/indexer.delta.sh)
      Dez 26 09:35:07 localhost CRON[16182]: pam_unix(crond:session): session closed for user groarchive
      Dez 26 09:35:07 localhost systemd[1]: session-c143.scope: Deactivated successfully.
      Dez 26 09:35:07 localhost searchd[1926]: rotating index 'dailydelta1': success
      Dez 26 09:35:07 localhost searchd[1926]: rotating index: all indexes done
      Dez 26 09:35:17 localhost systemd[1]: Stopping User Manager for UID 460...
      Dez 26 09:35:17 localhost systemd[16184]: Stopped target Main User Target.
      Dez 26 09:35:17 localhost systemd[16184]: Stopped target Basic System.
      Dez 26 09:35:17 localhost systemd[16184]: Stopped target Paths.
      Dez 26 09:35:17 localhost systemd[16184]: Stopped target Sockets.
      Dez 26 09:35:17 localhost systemd[16184]: Stopped target Timers.
      Dez 26 09:35:17 localhost systemd[16184]: Stopped Daily Cleanup of User's Temporary Directories.
      Dez 26 09:35:17 localhost systemd[16184]: Closed D-Bus User Message Bus Socket.
      Dez 26 09:35:17 localhost systemd[16184]: Stopped Create User's Volatile Files and Directories.
      Dez 26 09:35:17 localhost systemd[16184]: Removed slice User Application Slice.
      Dez 26 09:35:17 localhost systemd[16184]: Reached target Shutdown.
      Dez 26 09:35:17 localhost systemd[16184]: Finished Exit the Session.
      Dez 26 09:35:17 localhost systemd[16184]: Reached target Exit the Session.
      Dez 26 09:35:17 localhost systemd[1]: user@460.service: Deactivated successfully.
      Dez 26 09:35:17 localhost systemd[1]: Stopped User Manager for UID 460.
      Dez 26 09:35:17 localhost systemd[1]: Stopping User Runtime Directory /run/user/460...
      Dez 26 09:35:17 localhost systemd[1]: run-user-460.mount: Deactivated successfully.
      Dez 26 09:35:17 localhost systemd[1]: user-runtime-dir@460.service: Deactivated successfully.
      Dez 26 09:35:17 localhost systemd[1]: Stopped User Runtime Directory /run/user/460.
      Dez 26 09:35:17 localhost systemd[1]: Removed slice User Slice of UID 460.
      Dez 26 09:35:36 localhost jvb.sh[1901]: Dez. 26, 2024 9:35:36 VORM. org.jitsi.utils.logging2.LoggerImpl log
      Dez 26 09:35:36 localhost jvb.sh[1901]: INFORMATION: Running expire()
      Dez 26 09:35:36 localhost jvb.sh[1901]: INFORMATION: Performed a successful health check in PT0.00001S. Sticky failure: false
      Dez 26 09:36:36 localhost jvb.sh[1901]: Dez. 26, 2024 9:36:36 VORM. org.jitsi.utils.logging2.LoggerImpl log
      Dez 26 09:36:36 localhost jvb.sh[1901]: INFORMATION: Running expire()
      Dez 26 09:36:36 localhost jvb.sh[1901]: INFORMATION: Performed a successful health check in PT0.000009S. Sticky failure: false
      Dez 26 09:36:53 localhost systemd[1]: Started Run grommunio Files cron-job every 15 minutes.
      Dez 26 09:36:53 localhost systemd[1]: grommunio-files-cron.service: Deactivated successfully.
      Dez 26 09:37:07 localhost systemd[15749]: Created slice User Background Tasks Slice.
      Dez 26 09:37:07 localhost systemd[15749]: Starting Cleanup of User's Temporary Files and Directories...
      Dez 26 09:37:07 localhost systemd[15749]: Finished Cleanup of User's Temporary Files and Directories.
      Dez 26 09:37:15 localhost rspamd[2362]: (controller) <q6ecuh>; monitored; rspamd_monitored_dns_cb: DNS reply returned 'no error' for dwl.dnswl.org while 'no records with this name' was expected when querying for 'Wmsu4li4ltewgfMW-BB99nLNVXYJ.dwl.dnswl.org'(likely DNS spoofing or BL internal issues)
      Dez 26 09:37:36 localhost jvb.sh[1901]: Dez. 26, 2024 9:37:36 VORM. org.jitsi.utils.logging2.LoggerImpl log
      Dez 26 09:37:36 localhost jvb.sh[1901]: INFORMATION: Running expire()
      Dez 26 09:37:36 localhost jvb.sh[1901]: INFORMATION: Performed a successful health check in PT0.000017S. Sticky failure: false
      Dez 26 09:37:53 localhost grommunio-chat[1899]: {"timestamp":"2024-12-26 09:37:53.527 +01:00","level":"info","msg":"SimpleWorker: Job is complete","caller":"jobs/base_workers.go:101","worker_name":"ExpiryNotify","job_id":"ze5uiii49inc7e97fk4o1jm97e","job_type":"expiry_notify","job_create_at":"Dec 26 08:37:48.319"}
      Dez 26 09:38:36 localhost jvb.sh[1901]: Dez. 26, 2024 9:38:36 VORM. org.jitsi.utils.logging2.LoggerImpl log
      Dez 26 09:38:36 localhost jvb.sh[1901]: INFORMATION: Running expire()
      Dez 26 09:38:36 localhost jvb.sh[1901]: INFORMATION: Performed a successful health check in PT0.000009S. Sticky failure: false
      Dez 26 09:39:00 localhost postfix/smtpd[16878]: connect from localhost[::1]
      Dez 26 09:39:00 localhost rspamd[2361]: (rspamd_proxy) <5445c4>; proxy; proxy_accept_socket: accepted milter connection from ::1 port 40344
      Dez 26 09:39:00 localhost postfix/smtpd[16878]: discarding EHLO keywords: CHUNKING
      Dez 26 09:39:00 localhost postfix/smtpd[16878]: 1A3DD6CE4CD: client=localhost[::1]
      Dez 26 09:39:00 localhost rspamd[2361]: (rspamd_proxy) <5445c4>; milter; rspamd_milter_process_command: got connection from [::1]:39280
      Dez 26 09:39:00 localhost postfix/cleanup[16881]: 1A3DD6CE4CD: message-id=<AuxXxilium/arc/issues/5362@github.com>
      Dez 26 09:39:00 localhost postfix/cleanup[16881]: 1A3DD6CE4CD: resent-message-id=<20241226083900.1A3DD6CE4CD@grommunio.tsu-pe.de>
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <eea969>; task; rspamd_worker_body_handler: accepted connection from ::1 port 47426, task ptr: 00000000036D41D8
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; task; rspamd_message_parse: loaded message; id: <AuxXxilium/arc/issues/5362@github.com>; queue-id: <1A3DD6CE4CD>; size: 10331; checksum: <7a8fd00404d4deb259998bfbecc7b9fc>
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; task; rspamd_mime_part_detect_language: detected part language: en
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; task; dkim_module_key_handler: stored DKIM key for pf2023._domainkey.github.com in LRU cache for 997 seconds, 11/2000 elements in the cache
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; task; rspamd_spf_record_postprocess: increasing ttl from 256 to 300 as it lower than a limit
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; task; rspamd_spf_maybe_return: stored SPF record for outlook.de (0xd4fc1ba5c2ca2db5) in LRU cache for 300 seconds, 4/2000 elements in the cache
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; task; finalize_item: slow asynchronous rule: RBL_SEM(540): 341.46 ms; no idle timer is needed
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; task; bayes_classify: not classified as ham. The ham class needs more training samples. Currently: 0; minimum 200 required
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; lua; greylist.lua:405: Downgrading metric action from "greylist" to "no action"
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; lua; greylist.lua:410: greylisting pass (meta) until Fri, 27 Dec 2024 08:39:00 GMT
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; lua; neural.lua:355: skip ham sample to keep spam/ham balance; probability 1; 0 spam and 1 ham vectors stored
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; task; rspamd_task_write_log: id: <AuxXxilium/arc/issues/5362@github.com>, qid: <1A3DD6CE4CD>, ip: 80.140.205.190, from: <a.kaelber@outlook.de>, (default: F (no action): [9.85/200.00] [VIOLATED_DIRECT_SPF(3.50){},RBL_SPAMHAUS_PBL(2.00){80.140.205.190:from;},RCVD_UNAUTH_PBL(2.00){},URI_COUNT_ODD(1.00){1;},MV_CASE(0.50){},ZERO_FONT(0.50){5;},MANY_INVISIBLE_PARTS(0.40){5;},MAILLIST(-0.13){generic;},BAD_REP_POLICIES(0.10){},MIME_GOOD(-0.10){multipart/alternative;text/plain;},RCVD_NO_TLS_LAST(0.10){},HAS_LIST_UNSUB(-0.01){},ARC_ALLOW(0.00){google.com:s=arc-20240605:i=1;},ASN(0.00){asn:3320, ipnet:80.128.0.0/12, country:DE;},DKIM_TRACE(0.00){github.com:+;},DMARC_POLICY_ALLOW(0.00){github.com;reject;},DMARC_POLICY_ALLOW_WITH_FAILURES(0.00){},FETCHMAIL(0.00){},FORGED_RECIPIENTS_MAILLIST(0.00){},FORGED_SENDER_MAILLIST(0.00){},FREEMAIL_ENVFROM(0.00){outlook.de;},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){notifications@github.com;a.kaelber@outlook.de;},GREYLIST(0.00){pass;meta;},HAS_REPLYTO(0.00){reply+ADC47GC2JY345FOJX3UNRV6FPD3LPEVBNHHKI6RRI4@reply.github.com;},MID_RHS_MATCH_FROM(0.00){},MIME_TRACE(0.00){0:+;1:+;2:~;},MISSING_XM_UA(0.00){},RCPT_COUNT_TWO(0.00){2;},RCVD_COUNT_FIVE(0.00){6;},RECEIVED_SPAMHAUS_PBL(0.00){80.140.205.190:received;},REPLYTO_DOM_NEQ_FROM_DOM(0.00){},REPLYTO_DOM_NEQ_TO_DOM(0.00){},R_DKIM_ALLOW(0.00){github.com:s=pf2023;},R_SPF_SOFTFAIL(0.00){~all;},TAGGED_FROM(0.00){SRS=k7RsW=TT=github.com=noreply;},TO_DN_ALL(0.00){}]), len: 10331, time: 407.667ms, dns req: 38, digest: <7a8fd00404d4deb259998bfbecc7b9fc>, rcpts: <andreas.kaelber@tsu-pe.de>, mime_rcpts: <arc@noreply.github.com,subscribed@noreply.github.com>
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <1A3DD6>; task; rspamd_protocol_http_reply: regexp statistics: 208 pcre regexps scanned, 2 regexps matched, 179 regexps total, 11 regexps cached, 37.94KiB scanned using pcre, 37.94KiB scanned total
      Dez 26 09:39:00 localhost postfix/qmgr[2457]: 1A3DD6CE4CD: from=<a.kaelber+SRS=k7RsW=TT=github.com=noreply@outlook.de>, size=10614, nrcpt=2 (queue active)
      Dez 26 09:39:00 localhost piler-smtp[1897]: connected from 127.0.0.1:49968 on fd=6 (active connections: 1)
      Dez 26 09:39:00 localhost postfix/smtpd[16878]: 866926CE4D6: client=localhost[::1]
      Dez 26 09:39:00 localhost piler-smtp[1897]: received: KGJMVR4NERYC3ORO, from=SRS@k7RsW=TT=github.com=noreply, size=10572, client=127.0.0.1, fd=6, fsync=4967
      Dez 26 09:39:00 localhost piler-smtp[1897]: disconnected from 127.0.0.1 on fd=6, slot=0, reason=done (0 active connections)
      Dez 26 09:39:00 localhost postfix/smtp[16882]: 1A3DD6CE4CD: to=<archive@grommunio.tsu-pe.de>, relay=127.0.0.1[127.0.0.1]:2693, delay=0.46, delays=0.44/0.01/0/0.01, dsn=2.0.0, status=sent (250 OK <KGJMVR4NERYC3ORO>)
      Dez 26 09:39:00 localhost delivery-queue[2140]: remote=[::1] from=<a.kaelber+SRS=k7RsW=TT=github.com=noreply@outlook.de> to={andreas.kaelber@tsu-pe.de} return OK, queue-id:58
      Dez 26 09:39:00 localhost postfix/smtp[16882]: 1A3DD6CE4CD: to=<andreas.kaelber@tsu-pe.de>, relay=::1[::1]:24, delay=0.46, delays=0.44/0.02/0/0, dsn=2.0.0, status=sent (250 Ok queue-id: 58)
      Dez 26 09:39:00 localhost postfix/qmgr[2457]: 1A3DD6CE4CD: removed
      Dez 26 09:39:00 localhost postfix/cleanup[16881]: 866926CE4D6: message-id=<AuxXxilium/arc/issues/5362/2562316615@github.com>
      Dez 26 09:39:00 localhost postfix/cleanup[16881]: 866926CE4D6: resent-message-id=<20241226083900.866926CE4D6@grommunio.tsu-pe.de>
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <ae75a0>; task; rspamd_worker_body_handler: accepted connection from 127.0.0.1 port 40456, task ptr: 00000000037506B8
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <866926>; task; rspamd_message_parse: loaded message; id: <AuxXxilium/arc/issues/5362/2562316615@github.com>; queue-id: <866926CE4D6>; size: 11152; checksum: <95bf3322675650d76a9c0924190b3fe7>
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <866926>; task; rspamd_mime_part_detect_language: detected part language: en
      Dez 26 09:39:00 localhost piler[1918]: 1/KGJMVR4NERYC3ORO: 50000000676d162e22c9c8dc008d8bfb4b10, size=10572/4624, attachments=0, reference=, message-id=<AuxXxilium/arc/issues/5362@github.com>, retention=2557, folder=0, delay=0.0176, status=stored
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <866926>; lua; replies.lua:134: ignoring reply to <AuxXxilium/arc/issues/5362@github.com> as no recipients are matching hash
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <866926>; lua; spf.lua:163: use cached record for outlook.de (0xd4fc1ba5c2ca2db5) in LRU cache for 300 seconds
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <866926>; task; bayes_classify: not classified as ham. The ham class needs more training samples. Currently: 0; minimum 200 required
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <866926>; lua; greylist.lua:405: Downgrading metric action from "greylist" to "no action"
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <866926>; lua; greylist.lua:410: greylisting pass (meta) until Fri, 27 Dec 2024 08:39:00 GMT
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <866926>; lua; neural.lua:355: skip ham sample to keep spam/ham balance; probability 1; 0 spam and 1 ham vectors stored
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <866926>; task; rspamd_task_write_log: id: <AuxXxilium/arc/issues/5362/2562316615@github.com>, qid: <866926CE4D6>, ip: 80.140.205.190, from: <a.kaelber@outlook.de>, (default: F (no action): [9.85/200.00] [VIOLATED_DIRECT_SPF(3.50){},RBL_SPAMHAUS_PBL(2.00){80.140.205.190:from;},RCVD_UNAUTH_PBL(2.00){},URI_COUNT_ODD(1.00){5;},MV_CASE(0.50){},ZERO_FONT(0.50){5;},MANY_INVISIBLE_PARTS(0.40){5;},MAILLIST(-0.13){generic;},BAD_REP_POLICIES(0.10){},MIME_GOOD(-0.10){multipart/alternative;text/plain;},RCVD_NO_TLS_LAST(0.10){},HAS_LIST_UNSUB(-0.01){},ARC_ALLOW(0.00){google.com:s=arc-20240605:i=1;},ASN(0.00){asn:3320, ipnet:80.128.0.0/12, country:DE;},DKIM_TRACE(0.00){github.com:+;},DMARC_POLICY_ALLOW(0.00){github.com;reject;},DMARC_POLICY_ALLOW_WITH_FAILURES(0.00){},FETCHMAIL(0.00){},FORGED_RECIPIENTS_MAILLIST(0.00){},FORGED_SENDER_MAILLIST(0.00){},FREEMAIL_ENVFROM(0.00){outlook.de;},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){notifications@github.com;a.kaelber@outlook.de;},GREYLIST(0.00){pass;meta;},HAS_REPLYTO(0.00){reply+ADC47GFKIBB22HHY4HENSGWFPD3MHEVBNHHKI6RRI4@reply.github.com;},MID_RHS_MATCH_FROM(0.00){},MIME_TRACE(0.00){0:+;1:+;2:~;},MISSING_XM_UA(0.00){},RCPT_COUNT_TWO(0.00){2;},RCVD_COUNT_FIVE(0.00){6;},RECEIVED_SPAMHAUS_PBL(0.00){80.140.205.190:received;},REPLYTO_DOM_NEQ_FROM_DOM(0.00){},REPLYTO_DOM_NEQ_TO_DOM(0.00){},R_DKIM_ALLOW(0.00){github.com:s=pf2023;},R_SPF_SOFTFAIL(0.00){~all:c;},TAGGED_FROM(0.00){SRS=k7RsW=TT=github.com=noreply;},TO_DN_ALL(0.00){}]), len: 11152, time: 64.392ms, dns req: 32, digest: <95bf3322675650d76a9c0924190b3fe7>, rcpts: <andreas.kaelber@tsu-pe.de>, mime_rcpts: <arc@noreply.github.com,subscribed@noreply.github.com>
      Dez 26 09:39:00 localhost rspamd[2366]: (normal) <866926>; task; rspamd_protocol_http_reply: regexp statistics: 228 pcre regexps scanned, 3 regexps matched, 179 regexps total, 11 regexps cached, 41.80KiB scanned using pcre, 41.80KiB scanned total
      Dez 26 09:39:00 localhost postfix/qmgr[2457]: 866926CE4D6: from=<a.kaelber+SRS=k7RsW=TT=github.com=noreply@outlook.de>, size=11437, nrcpt=2 (queue active)
      Dez 26 09:39:00 localhost piler-smtp[1897]: connected from 127.0.0.1:49984 on fd=6 (active connections: 1)
      Dez 26 09:39:00 localhost postfix/smtpd[16878]: disconnect from localhost[::1] ehlo=1 mail=2 rcpt=2 data=2 quit=1 commands=8
      Dez 26 09:39:00 localhost rspamd[2361]: (rspamd_proxy) <93ecef>; proxy; proxy_milter_finish_handler: finished milter connection
      Dez 26 09:39:00 localhost delivery-queue[2140]: remote=[::1] from=<a.kaelber+SRS=k7RsW=TT=github.com=noreply@outlook.de> to={andreas.kaelber@tsu-pe.de} return OK, queue-id:59
      Dez 26 09:39:00 localhost postfix/smtp[16883]: 866926CE4D6: to=<andreas.kaelber@tsu-pe.de>, relay=::1[::1]:24, delay=0.13, delays=0.12/0/0/0, dsn=2.0.0, status=sent (250 Ok queue-id: 59)
      Dez 26 09:39:00 localhost piler-smtp[1897]: received: A8HV3SJMVQZKXX55, from=SRS@k7RsW=TT=github.com=noreply, size=11394, client=127.0.0.1, fd=6, fsync=6650
      Dez 26 09:39:00 localhost postfix/smtp[16882]: 866926CE4D6: to=<archive@grommunio.tsu-pe.de>, relay=127.0.0.1[127.0.0.1]:2693, delay=0.14, delays=0.12/0/0/0.01, dsn=2.0.0, status=sent (250 OK <A8HV3SJMVQZKXX55>)
      Dez 26 09:39:00 localhost postfix/qmgr[2457]: 866926CE4D6: removed
      Dez 26 09:39:01 localhost piler[1918]: 1/A8HV3SJMVQZKXX55: 50000000676d162f23df7e9c00d9ed716023, size=11394/4848, attachments=0, reference=<AuxXxilium/arc/issues/5362@github.com>, message-id=<AuxXxilium/arc/issues/5362/2562316615@github.com>, retention=2557, folder=0, delay=0.0247, status=stored
      Dez 26 09:39:36 localhost jvb.sh[1901]: Dez. 26, 2024 9:39:36 VORM. org.jitsi.utils.logging2.LoggerImpl log
      Dez 26 09:39:36 localhost jvb.sh[1901]: INFORMATION: Running expire()
      Dez 26 09:39:36 localhost jvb.sh[1901]: INFORMATION: Performed a successful health check in PT0.000013S. Sticky failure: false
      Dez 26 09:40:00 localhost grommunio-chat[1899]: {"timestamp":"2024-12-26 09:40:00.011 +01:00","level":"error","msg":"Failed to get system bot","caller":"app/post.go:2216","component":"post_reminders","error":"GetSystemBot: List of admins is empty."}
      Dez 26 09:40:01 localhost systemd[1]: Created slice User Slice of UID 460.
      Dez 26 09:40:01 localhost systemd[1]: Starting User Runtime Directory /run/user/460...
      Dez 26 09:40:01 localhost systemd[1]: Finished User Runtime Directory /run/user/460.
      Dez 26 09:40:01 localhost systemd[1]: Starting User Manager for UID 460...
      Dez 26 09:40:01 localhost (systemd)[17003]: pam_unix(systemd-user:session): session opened for user groarchive by (uid=0)
      Dez 26 09:40:01 localhost systemd[17003]: Queued start job for default target Main User Target.
      Dez 26 09:40:01 localhost systemd[17003]: Created slice User Application Slice.
      Dez 26 09:40:01 localhost systemd[17003]: Started Daily Cleanup of User's Temporary Directories.
      Dez 26 09:40:01 localhost systemd[17003]: Reached target Paths.
      Dez 26 09:40:01 localhost systemd[17003]: Reached target Timers.
      Dez 26 09:40:01 localhost systemd[17003]: Starting D-Bus User Message Bus Socket...
      Dez 26 09:40:01 localhost systemd[17003]: Starting Create User's Volatile Files and Directories...
      Dez 26 09:40:01 localhost systemd[17003]: Finished Create User's Volatile Files and Directories.
      Dez 26 09:40:01 localhost systemd[17003]: Listening on D-Bus User Message Bus Socket.
      Dez 26 09:40:01 localhost systemd[17003]: Reached target Sockets.
      Dez 26 09:40:01 localhost systemd[17003]: Reached target Basic System.
      Dez 26 09:40:01 localhost systemd[17003]: Reached target Main User Target.
      Dez 26 09:40:01 localhost systemd[17003]: Startup finished in 117ms.
      Dez 26 09:40:01 localhost systemd[1]: Started User Manager for UID 460.
      Dez 26 09:40:01 localhost systemd[1]: Started Session c144 of User groarchive.
      Dez 26 09:40:01 localhost systemd[1]: Started Session c145 of User groarchive.
      Dez 26 09:40:01 localhost cron[17000]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
      Dez 26 09:40:01 localhost CRON[17012]: (groarchive) CMD (/usr/bin/find /var/lib/grommunio-archive/error -type f | wc -l > /var/lib/grommunio-archive/stat/error)
      Dez 26 09:40:01 localhost cron[17001]: pam_unix(crond:session): session opened for user groarchive by (uid=0)
      Dez 26 09:40:01 localhost CRON[17015]: (groarchive) CMD (/usr/bin/find /usr/share/grommunio-archive/archive/tmp -type f -name i.\* -exec rm -f {} \;)
      Dez 26 09:40:01 localhost CRON[17000]: (groarchive) CMDEND (/usr/bin/find /var/lib/grommunio-archive/error -type f | wc -l > /var/lib/grommunio-archive/stat/error)
      Dez 26 09:40:01 localhost CRON[17000]: pam_unix(crond:session): session closed for user groarchive
      Dez 26 09:40:01 localhost CRON[17001]: (groarchive) CMDEND (/usr/bin/find /usr/share/grommunio-archive/archive/tmp -type f -name i.\* -exec rm -f {} \;)
      Dez 26 09:40:01 localhost systemd[1]: session-c144.scope: Deactivated successfully.
      Dez 26 09:40:01 localhost CRON[17001]: pam_unix(crond:session): session closed for user groarchive
      Dez 26 09:40:01 localhost systemd[1]: session-c145.scope: Deactivated successfully.
      Dez 26 09:40:11 localhost systemd[1]: Stopping User Manager for UID 460...
      Dez 26 09:40:11 localhost systemd[17003]: Stopped target Main User Target.
      Dez 26 09:40:11 localhost systemd[17003]: Stopped target Basic System.
      Dez 26 09:40:11 localhost systemd[17003]: Stopped target Paths.
      Dez 26 09:40:11 localhost systemd[17003]: Stopped target Sockets.
      Dez 26 09:40:11 localhost systemd[17003]: Stopped target Timers.
      Dez 26 09:40:11 localhost systemd[17003]: Stopped Daily Cleanup of User's Temporary Directories.
      Dez 26 09:40:11 localhost systemd[17003]: Closed D-Bus User Message Bus Socket.
      Dez 26 09:40:11 localhost systemd[17003]: Stopped Create User's Volatile Files and Directories.
      Dez 26 09:40:11 localhost systemd[17003]: Removed slice User Application Slice.
      Dez 26 09:40:11 localhost systemd[17003]: Reached target Shutdown.
      Dez 26 09:40:11 localhost systemd[17003]: Finished Exit the Session.
      Dez 26 09:40:11 localhost systemd[17003]: Reached target Exit the Session.
      Dez 26 09:40:11 localhost systemd[1]: user@460.service: Deactivated successfully.
      Dez 26 09:40:11 localhost systemd[1]: Stopped User Manager for UID 460.
      Dez 26 09:40:11 localhost systemd[1]: Stopping User Runtime Directory /run/user/460...
      Dez 26 09:40:11 localhost systemd[1]: run-user-460.mount: Deactivated successfully.
      Dez 26 09:40:11 localhost systemd[1]: user-runtime-dir@460.service: Deactivated successfully.
      Dez 26 09:40:11 localhost systemd[1]: Stopped User Runtime Directory /run/user/460.
      Dez 26 09:40:11 localhost systemd[1]: Removed slice User Slice of UID 460.
      Dez 26 09:40:36 localhost jvb.sh[1901]: Dez. 26, 2024 9:40:36 VORM. org.jitsi.utils.logging2.LoggerImpl log
      Dez 26 09:40:36 localhost jvb.sh[1901]: INFORMATION: Running expire()
      Dez 26 09:40:36 localhost jvb.sh[1901]: INFORMATION: Performed a successful health check in PT0.00001S. Sticky failure: false
      Dez 26 09:41:02 localhost postfix/smtpd[17131]: connect from localhost[::1]
      Dez 26 09:41:02 localhost rspamd[2361]: (rspamd_proxy) <6ff53e>; proxy; proxy_accept_socket: accepted milter connection from ::1 port 36104
      Dez 26 09:41:02 localhost postfix/smtpd[17131]: discarding EHLO keywords: CHUNKING
      Dez 26 09:41:02 localhost postfix/smtpd[17131]: 0CAED6CE4CD: client=localhost[::1]
      Dez 26 09:41:02 localhost rspamd[2361]: (rspamd_proxy) <6ff53e>; milter; rspamd_milter_process_command: got connection from [::1]:38406
      Dez 26 09:41:02 localhost postfix/cleanup[17134]: 0CAED6CE4CD: message-id=<AuxXxilium/arc/issue/5362/issue_event/15764277590@github.com>
      Dez 26 09:41:02 localhost postfix/cleanup[17134]: 0CAED6CE4CD: resent-message-id=<20241226084102.0CAED6CE4CD@grommunio.tsu-pe.de>
      Dez 26 09:41:02 localhost rspamd[2365]: (normal) <cfa44f>; task; rspamd_worker_body_handler: accepted connection from ::1 port 34908, task ptr: 0000000003510798
      Dez 26 09:41:02 localhost rspamd[2365]: (normal) <0CAED6>; task; rspamd_message_parse: loaded message; id: <AuxXxilium/arc/issue/5362/issue_event/15764277590@github.com>; queue-id: <0CAED6CE4CD>; size: 10986; checksum: <bbc755f724a9fe9a7e9c0c7298537f9f>
      Dez 26 09:41:02 localhost rspamd[2365]: (normal) <0CAED6>; task; rspamd_mime_part_detect_language: detected part language: en
      Dez 26 09:41:02 localhost rspamd[2365]: (normal) <0CAED6>; lua; replies.lua:134: ignoring reply to <AuxXxilium/arc/issues/5362@github.com> as no recipients are matching hash
      Dez 26 09:41:02 localhost rspamd[2365]: (normal) <0CAED6>; task; rspamd_spf_record_postprocess: increasing ttl from 134 to 300 as it lower than a limit
      Dez 26 09:41:02 localhost rspamd[2365]: (normal) <0CAED6>; task; rspamd_spf_maybe_return: stored SPF record for outlook.de (0xd4fc1ba5c2ca2db5) in LRU cache for 300 seconds, 3/2000 elements in the cache
      Dez 26 09:41:02 localhost rspamd[2365]: (normal) <0CAED6>; task; finalize_item: slow asynchronous rule: RBL_SEM(540): 354.92 ms; no idle timer is needed
      Dez 26 09:41:02 localhost rspamd[2365]: (normal) <0CAED6>; task; finalize_item: slow asynchronous rule: MSBL_EBL(513): 822.91 ms; no idle timer is needed
      Dez 26 09:41:03 localhost rspamd[2365]: (normal) <0CAED6>; task; finalize_item: slow asynchronous rule: SURBL_MULTI(531): 1032.08 ms; no idle timer is needed
      Dez 26 09:41:03 localhost rspamd[2365]: (normal) <0CAED6>; task; bayes_classify: not classified as ham. The ham class needs more training samples. Currently: 0; minimum 200 required
      Dez 26 09:41:03 localhost rspamd[2365]: (normal) <0CAED6>; lua; greylist.lua:405: Downgrading metric action from "greylist" to "no action"
      Dez 26 09:41:03 localhost rspamd[2365]: (normal) <0CAED6>; lua; greylist.lua:410: greylisting pass (meta) until Fri, 27 Dec 2024 08:41:03 GMT
      Dez 26 09:41:03 localhost rspamd[2365]: (normal) <0CAED6>; lua; neural.lua:355: skip ham sample to keep spam/ham balance; probability 1; 0 spam and 1 ham vectors stored
      Dez 26 09:41:03 localhost rspamd[2365]: (normal) <0CAED6>; task; rspamd_task_write_log: id: <AuxXxilium/arc/issue/5362/issue_event/15764277590@github.com>, qid: <0CAED6CE4CD>, ip: 80.140.205.190, from: <a.kaelber@outlook.de>, (default: F (no action): [9.85/200.00] [VIOLATED_DIRECT_SPF(3.50){},RBL_SPAMHAUS_PBL(2.00){80.140.205.190:from;},RCVD_UNAUTH_PBL(2.00){},URI_COUNT_ODD(1.00){1;},MV_CASE(0.50){},ZERO_FONT(0.50){5;},MANY_INVISIBLE_PARTS(0.40){5;},MAILLIST(-0.13){generic;},BAD_REP_POLICIES(0.10){},MIME_GOOD(-0.10){multipart/alternative;text/plain;},RCVD_NO_TLS_LAST(0.10){},HAS_LIST_UNSUB(-0.01){},ARC_ALLOW(0.00){google.com:s=arc-20240605:i=1;},ASN(0.00){asn:3320, ipnet:80.128.0.0/12, country:DE;},DKIM_TRACE(0.00){github.com:+;},DMARC_POLICY_ALLOW(0.00){github.com;reject;},DMARC_POLICY_ALLOW_WITH_FAILURES(0.00){},FETCHMAIL(0.00){},FORGED_RECIPIENTS_MAILLIST(0.00){},FORGED_SENDER_MAILLIST(0.00){},FREEMAIL_ENVFROM(0.00){outlook.de;},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){notifications@github.com;a.kaelber@outlook.de;},GREYLIST(0.00){pass;meta;},HAS_REPLYTO(0.00){reply+ADC47GGP5IVTKN43KVYASHGFPD3VREVBNHHKI6RRI4@reply.github.com;},MID_RHS_MATCH_FROM(0.00){},MIME_TRACE(0.00){0:+;1:+;2:~;},MISSING_XM_UA(0.00){},RCPT_COUNT_TWO(0.00){2;},RCVD_COUNT_FIVE(0.00){6;},RECEIVED_SPAMHAUS_PBL(0.00){80.140.205.190:received;},REPLYTO_DOM_NEQ_FROM_DOM(0.00){},REPLYTO_DOM_NEQ_TO_DOM(0.00){},R_DKIM_ALLOW(0.00){github.com:s=pf2023;},R_SPF_SOFTFAIL(0.00){~all;},TAGGED_FROM(0.00){SRS=k7RsW=TT=github.com=noreply;},TO_DN_ALL(0.00){}]), len: 10986, time: 1104.608ms, dns req: 38, digest: <bbc755f724a9fe9a7e9c0c7298537f9f>, rcpts: <andreas.kaelber@tsu-pe.de>, mime_rcpts: <arc@noreply.github.com,subscribed@noreply.github.com>
      Dez 26 09:41:03 localhost rspamd[2365]: (normal) <0CAED6>; task; rspamd_protocol_http_reply: regexp statistics: 218 pcre regexps scanned, 3 regexps matched, 179 regexps total, 11 regexps cached, 39.62KiB scanned using pcre, 39.62KiB scanned total
      Dez 26 09:41:03 localhost postfix/qmgr[2457]: 0CAED6CE4CD: from=<a.kaelber+SRS=k7RsW=TT=github.com=noreply@outlook.de>, size=11268, nrcpt=2 (queue active)
      Dez 26 09:41:03 localhost rspamd[2361]: (rspamd_proxy) <281ccf>; proxy; proxy_milter_finish_handler: finished milter connection
      Dez 26 09:41:03 localhost postfix/smtpd[17131]: disconnect from localhost[::1] ehlo=1 mail=1 rcpt=1 data=1 quit=1 commands=5
      Dez 26 09:41:03 localhost piler-smtp[1897]: connected from 127.0.0.1:46850 on fd=6 (active connections: 1)
      Dez 26 09:41:03 localhost piler-smtp[1897]: received: 42DSV9GIZSUY6X56, from=SRS@k7RsW=TT=github.com=noreply, size=11228, client=127.0.0.1, fd=6, fsync=4481
      Dez 26 09:41:03 localhost piler-smtp[1897]: disconnected from 127.0.0.1 on fd=6, slot=0, reason=done (0 active connections)
      Dez 26 09:41:03 localhost postfix/smtp[17136]: 0CAED6CE4CD: to=<archive@grommunio.tsu-pe.de>, relay=127.0.0.1[127.0.0.1]:2693, delay=1.2, delays=1.1/0.01/0/0.01, dsn=2.0.0, status=sent (250 OK <42DSV9GIZSUY6X56>)
      Dez 26 09:41:03 localhost delivery-queue[2140]: remote=[::1] from=<a.kaelber+SRS=k7RsW=TT=github.com=noreply@outlook.de> to={andreas.kaelber@tsu-pe.de} return OK, queue-id:60
      Dez 26 09:41:03 localhost postfix/smtp[17136]: 0CAED6CE4CD: to=<andreas.kaelber@tsu-pe.de>, relay=::1[::1]:24, delay=1.2, delays=1.1/0.02/0/0, dsn=2.0.0, status=sent (250 Ok queue-id: 60)
      Dez 26 09:41:03 localhost postfix/qmgr[2457]: 0CAED6CE4CD: removed
      Dez 26 09:41:03 localhost piler[1917]: 0/42DSV9GIZSUY6X56: 50000000676d16a927ba538400f40ea60178, size=11228/4864, attachments=0, reference=<AuxXxilium/arc/issues/5362@github.com>, message-id=<AuxXxilium/arc/issue/5362/issue_event/15764277590@github.com>, retention=2557, folder=0, delay=0.0198, status=stored
      localhost:~ #
        Andy localhost:~ # journalctl -f
        Erstens: "localhost"?! Da ist doch was falsch in deinem setup.
        https://docs.grommunio.com/admin/quickstart.html#minimum-requirements
        Zweitens: journalctl -f (--follow) ist dafür da sich das fortgehende log anzuschauen (so wie ein tail -f).
        Drittens:
        Das haben wir doch schon etliche male durchgekaut. Das passiert halt immer wieder. Falls es dich wirklich so sehr stört dann wende dich bitte an die OpenSuSE community via IRC oder sonstwas und ich gehe davon aus das die dir auch nur sagen das dies halt hin und wieder ist und sich dann auch von ganz alleine wieder löst.
        crpb locked the discussion .
