The problem with the configwizard only occurs if you do it directly in the terminal.
If you do it in a ssh session configwizard works!
After setting is up with the configwizard and restarting the services I see the changes in the configfile.
But running a dkim test tool it says the mail is not signet!
I tried to rerun the configwizard but it says no changes found and quits!
How can I reconfigure this?
Thank you for your tips!
