Hello Mister2,
Thanks for your post.
I updated my mail appliance:
Retrieving: grommunio-common-28.2-lp155.14.1.x86_64.rpm ..................................................................................................[done]
Retrieving: grommunio-cui-1.1.3.b0091e0-lp155.6.1.noarch (grommunio) (3/13), 61.8 KiB
Retrieving: grommunio-cui-1.1.3.b0091e0-lp155.6.1.noarch.rpm .................................................................................[done (9.9 KiB/s)]
Retrieving: grommunio-dbconf-1.1.1.da20a46-lp155.13.1.x86_64 (grommunio) (4/13), 27.4 KiB
Retrieving: grommunio-dbconf-1.1.1.da20a46-lp155.13.1.x86_64.rpm .............................................................................[done (8.5 KiB/s)]
Retrieving: grommunio-setup-1.1.14.768d394-lp155.71.1.noarch (grommunio) (5/13), 32.8 KiB
Retrieving: grommunio-setup-1.1.14.768d394-lp155.71.1.noarch.rpm .........................................................................................[done]
Retrieving: gromox-3.0.0.g21b0cd4-lp155.1.1.x86_64 (grommunio) (6/13), 2.2 MiB
Retrieving: gromox-3.0.0.g21b0cd4-lp155.1.1.x86_64.rpm .......................................................................................[done (1.6 MiB/s)]
Retrieving: gromox-debugsource-3.0.0.g21b0cd4-lp155.1.1.x86_64 (grommunio) (7/13), 1.1 MiB
Retrieving: gromox-debugsource-3.0.0.g21b0cd4-lp155.1.1.x86_64.rpm .......................................................................................[done]
Retrieving: libexmdbpp0-1.11.3.a477f82-lp155.305.1.x86_64 (grommunio) (8/13), 77.7 KiB
Retrieving: libexmdbpp0-1.11.3.a477f82-lp155.305.1.x86_64.rpm ............................................................................................[done]
Retrieving: mapi-header-php-1.7.0.be09cd6-lp155.13.1.noarch (grommunio) (9/13), 96.7 KiB
Retrieving: mapi-header-php-1.7.0.be09cd6-lp155.13.1.noarch.rpm .............................................................................[done (74.2 KiB/s)]
Retrieving: gromox-debuginfo-3.0.0.g21b0cd4-lp155.1.1.x86_64 (grommunio) (10/13), 22.7 MiB
Retrieving: gromox-debuginfo-3.0.0.g21b0cd4-lp155.1.1.x86_64.rpm ............................................................................[done (16.9 MiB/s)]
Retrieving: python3-pyexmdb-1.11.3.a477f82-lp155.305.1.x86_64 (grommunio) (11/13), 119.6 KiB
Retrieving: python3-pyexmdb-1.11.3.a477f82-lp155.305.1.x86_64.rpm ...........................................................................[done (74.9 KiB/s)]
Retrieving: grommunio-index-1.3.0.g2bd8a8c-lp155.13.1.x86_64 (grommunio) (12/13), 62.2 KiB
Retrieving: grommunio-index-1.3.0.g2bd8a8c-lp155.13.1.x86_64.rpm ............................................................................[done (62.2 KiB/s)]
Retrieving: grommunio-sync-2.3.1.a034e08-lp155.15.1.noarch (grommunio) (13/13), 265.5 KiB
Retrieving: grommunio-sync-2.3.1.a034e08-lp155.15.1.noarch.rpm ..............................................................................[done (76.7 KiB/s)]
Checking for file conflicts: .............................................................................................................................[done]
( 1/13) Installing: grommunio-admin-common-42.e17ec55-lp155.36.1.noarch ..................................................................................[done]
( 2/13) Installing: grommunio-common-28.2-lp155.14.1.x86_64 ..............................................................................................[done]
Failed to try-restart grommunio-cui@.service: Unit name grommunio-cui@.service is missing the instance name.
See system logs and 'systemctl status grommunio-cui@.service' for details.
( 3/13) Installing: grommunio-cui-1.1.3.b0091e0-lp155.6.1.noarch .........................................................................................[done]
( 4/13) Installing: grommunio-dbconf-1.1.1.da20a46-lp155.13.1.x86_64 .....................................................................................[done]
( 5/13) Installing: grommunio-setup-1.1.14.768d394-lp155.71.1.noarch .....................................................................................[done]
( 6/13) Installing: gromox-3.0.0.g21b0cd4-lp155.1.1.x86_64 ...............................................................................................[done]
( 7/13) Installing: gromox-debugsource-3.0.0.g21b0cd4-lp155.1.1.x86_64 ...................................................................................[done]
( 8/13) Installing: libexmdbpp0-1.11.3.a477f82-lp155.305.1.x86_64 ........................................................................................[done]
( 9/13) Installing: mapi-header-php-1.7.0.be09cd6-lp155.13.1.noarch ......................................................................................[done]
(10/13) Installing: gromox-debuginfo-3.0.0.g21b0cd4-lp155.1.1.x86_64 .....................................................................................[done]
(11/13) Installing: python3-pyexmdb-1.11.3.a477f82-lp155.305.1.x86_64 ....................................................................................[done]
(12/13) Installing: grommunio-index-1.3.0.g2bd8a8c-lp155.13.1.x86_64 .....................................................................................[done]
(13/13) Installing: grommunio-sync-2.3.1.a034e08-lp155.15.1.noarch .......................................................................................[done]
mail:~> systemctl status grommunio-cui@.service
Failed to get properties: Unit name grommunio-cui@.service is neither a valid invocation ID nor unit name.
After a reboot, sudo systemctl status nginx shows:
nginx.service - The nginx HTTP and reverse proxy server
Loaded: loaded (/usr/lib/systemd/system/nginx.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2025-10-01 15:47:56 BST; 2s ago
Process: 14786 ExecStartPre=/usr/sbin/nginx -t (code=exited, status=0/SUCCESS)
Main PID: 14787 (nginx)
Tasks: 2 (limit: 4915)
CGroup: /system.slice/nginx.service
├─ 14787 "nginx: master process /usr/sbin/nginx -g daemon off;"
└─ 14788 "nginx: worker process" "" "" "" "" "" "" "" "" ""
During a restart of nginx (sudo systemctl restart nginx), sudo journalctl -f shows:
Oct 01 15:48:30 mail systemd[1]: Stopping The nginx HTTP and reverse proxy server...
Oct 01 15:48:30 mail systemd[1]: nginx.service: Deactivated successfully.
Oct 01 15:48:30 mail systemd[1]: Stopped The nginx HTTP and reverse proxy server.
Oct 01 15:48:30 mail systemd[1]: Starting The nginx HTTP and reverse proxy server...
Oct 01 15:48:30 mail nginx[14935]: nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
Oct 01 15:48:30 mail nginx[14935]: nginx: configuration file /etc/nginx/nginx.conf test is successful
Oct 01 15:48:30 mail systemd[1]: Started The nginx HTTP and reverse proxy server.
which certainly looks better.
I can successfully connect to the admin web interface (https://mail.xxx.co.uk:8443/) and I can see no obvious problems.
However, I still receive a 500 error whenever I try to connect to the user web interface (https://mail.xxx.co.uk/web/).
