grom_du (disk usage) of all users
grommunio-admin fs du user will get that sooner or later i guess. I was still too lazy to work my way through there :P.
FYI: Mailbox-Size differs from Disk-Usage and Disk-Usage differs on $Filesystem - (-)
alias grom_du='grommunio-admin user query username maildir |sed 1,2d | while read -r user mdir; do printf "%s;%s;%s\n" "$(du -hs ${mdir}|cut -f1)" "$user" "$mdir"; done  |sort -h'
    Autodiscover for all those other Clients.
    WIP!
    bind9 template
    % cat ~/tmpl/srv
    ; vim:filetype=bindzone
                           TXT              "mailconf=https://grommunio-host.domain.tld/.well-known/autoconfig/mail/config-v1.1.xml"
    $ORIGIN domain.tld.
    _autodiscover._tcp IN  SRV    0  1  443 grommunio-host.domain.tld.
    _caldav._tcp       IN  SRV    0  0  0   .
    _caldavs._tcp          TXT              "path=/dav/calendars"
    _caldavs._tcp      IN  SRV    0  1  443 grommunio-host.domain.tld.
    _carddav._tcp      IN  SRV    0  0  0   .
    _carddavs._tcp         TXT              "path=/dav/addressbooks"
    _carddavs._tcp     IN  SRV    0  1  443 grommunio-host.domain.tld.
    _imap._tcp         IN  SRV    0  1  143 grommunio-host.domain.tld.
    _imaps._tcp        IN  SRV    0  1  993 grommunio-host.domain.tld.
    _pop3._tcp         IN  SRV    0  1  110 grommunio-host.domain.tld.
    _pop3s._tcp        IN  SRV    0  1  995 grommunio-host.domain.tld.
    _sieve._tcp        IN  SRV    0  0  0   .
    ;_sieve._tcp        IN  SRV 0 1 4190  grommunio-host.domain.tld.
    _smtp._tcp         IN  SRV    0  1  25  grommunio-host.domain.tld.
    _smtps._tcp        IN  SRV    0  0  0   .
    ;_smtps._tcp        IN  SRV 0 1 465 grommunio-host.domain.tld.
    _submission._tcp   IN  SRV    0  1  587 grommunio-host.domain.tld.
    autodiscover       IN  CNAME            grommunio-host.domain.tld.
    RFC 2782
    RFC 6186
    RFC 6764
      crpb
      unfortuanetly, this only seems to work for Outlook and iOS. Neither Apple Mail or Thunderbird do seem to care about these. I know that Thunderbird looks for something called Autoconfig and Apple Mail's autodiscover mechanism seems to be even more opaque. It's such a downer, that everyone seems to cook up their own solution for this.
        sbudach
        My Claws-Mail at least is happy with those imaps and submission-references.
        EDIT: Did a bit of reading on Thunderbird...
        https://wiki.mozilla.org/Thunderbird:Autoconfiguration
        https://wiki.mozilla.org/Thunderbird:Autoconfiguration:DNSBasedLookup
        Maybe there already is such an app or i think i will write my own little bottle-app to provide a backend for "TXT mailconf=uri.to.app/emaildomain.tld" which then does an SRV-Lookup and generate a config.xml with the corresponding fields...
        OR SOMETHING LIKE THAT o_0..
        Still need to test if those config.xml with "TXT mailconf=" entries even work now. Most references in the mozilla-wiki are dead...
          crpb
          Yeah… I read something about such an app. I wasn't aware, that you can invoke it as a result of a TXT DNS lookup…
          Well, each domain would just have an DNS TXT Entry Pointing to "mailconf=https://uri.to.app/dnsdomain.tld" to make it possible.
          For clarification an example with dig
          # dig +short TXT domainA.tld
          "v=spf1 mx -all"
          "mailconf=https://ac.my.app/mail/domainA.tld/config.xml"
          # dig +short TXT domainB.tld
          "v=spf1 mx -all"
          "mailconf=https://ac.my.app/mail/domainB.tld/config.xml"
          EDIT:
          And internally it should query all those SRV-Entries on "domainA|B|X.tld" and generate a config with the respective DNS-Priorities. So basically as default something like: incomingserver imap+ssl, outgoingserver submission+tls if you use that template from above.
          Nothing really test so far! Just a thought of how this could be done without all those other "A" subdomains (autoconfig|autodiscover.domain.tld) and no extra configuration needed at company-domain.tld.
          And after a bit of searching i at least found a few references. But not exactly what i was thinking about.
          https://rseichter.github.io/automx2/
          https://github.com/Monogramm/autodiscover-email-settings
          cheers!
          a month later
          BTRFS MAINTENANCE
          To not have to care so much about doing recommended regularly Maintenance-Tasks on the BTRFS Volumes you can install the Package btrfsmaintenance.
          There is also an article about disabling btrfsmaintenance but the note "Disabling automatic drive maintenance, in favor of manual maintenance, is desired." without any explanation is nor helpful at all.
          zypper refresh
          zypper install -y btrfsmaintenance
          # Let the script do most of the work on all (sub)volumes
          sed '/^BTRFS/s/\//auto/g' /etc/sysconfig/btrfsmaintenance -i
          systemctl restart btrfsmaintenance-refresh.service
          By default the Systemd-Timers btrfs.scrub and btrfs-balance are now active. I guess this enough for now.
          25 days later
          crpb To find the users and their mail directories, there is a single line command:
          echo "select maildir,username from users where maildir<>'';" | mysql -N grommunio | sort
          Hey Walter,
          that is certainly another Option. Currently i use the following in my scripts.
          _grom_query_maildir(){
            grommunio-admin user query --filter username="${1}" maildir
          2 months later
          Learn Ham - Update 2024.04.28 2024.06.26
          As i was bothered by the Spam-Handling on some Mails from an Mailinglist which always landed in my Junk-Folder i finally got around to create this little Function script.
          Both scripts can be configured to wait at least N Days before the Mail will be processed by the script.
          And aswell as in the original you can configure if it should delete the Mail after learning it.
          The HAM-Runner will mark messages as READ after indexing them if they aren't deleted.
          Additionally you can now provide optional parameters to rspamc to be able to use another RSPAMD Installation.
          grommunio-ham-run.sh
          .service, .timer & installscript in the folder
          grommunio-spam-run.sh
          Create HAM-LEARN-FOLDER for all users
          USERS=$(grommunio-admin user query username status maildir |awk '$2=="0/active" && $3 ~ /\/var\/lib\/gromox/ {print$1}')
          # this might say it failed but then the folder just exists already
          for USER in $USERS; do
          grommunio-admin exmdb $USER folder create -t IPF.Note --comment "HAM-Training" TRAIN-HAM 9;
          done
          PS: HowTo Moving mails automatically to Junk-Folder via Inbox-Rule https://community.grommunio.com/d/572-spam-handling/12
          Autodiscover
          GPO Copy/Paste
          <?xml version="1.0" encoding="utf-8"?>
          <RegistrySettings clsid="{A3CCFC41-DFDB-43a5-8D26-0FE8B954DA51}">
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeExplicitO365Endpoint" status="ExcludeExplicitO365Endpoint" image="11" changed="2023-01-06 06:48:06" uid="{3607AC9F-C086-4FF5-AD5E-DC8A2A8EC815}" bypassErrors="1"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeExplicitO365Endpoint" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeLastKnownGoodURL" status="ExcludeLastKnownGoodURL" image="11" changed="2023-01-06 06:47:24" uid="{A4BDDC22-D8C2-40E3-ABA8-2E4C4CE47558}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeLastKnownGoodURL" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeHttpsRootDomain" status="ExcludeHttpsRootDomain" image="11" changed="2023-01-06 06:47:28" uid="{A9023706-376D-4FB9-8E30-4BBBB0FA6981}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeHttpsRootDomain" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeHttpsAutoDiscoverDomain" status="ExcludeHttpsAutoDiscoverDomain" image="11" changed="2023-01-06 06:47:31" uid="{36E47622-6C23-4D1E-8ECB-07A350DFCFD0}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeHttpsAutoDiscoverDomain" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeHttpRedirect" status="ExcludeHttpRedirect" image="11" changed="2023-01-06 06:47:35" uid="{105A60A9-BBAC-40AF-88FC-7AF986D6A568}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeHttpRedirect" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeScpLookup" status="ExcludeScpLookup" image="11" changed="2023-01-06 06:47:39" uid="{699006E9-FB8F-492F-81F4-80472FFE8972}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeScpLookup" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeSrvRecord" status="ExcludeSrvRecord" image="11" changed="2023-01-06 06:47:45" uid="{5B7B8077-42E9-4671-A6B5-FBA0F0B277A7}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeSrvRecord" type="REG_DWORD" value="00000000"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="EnableOffice365ConfigService" status="EnableOffice365ConfigService" image="11" changed="2023-01-06 06:47:51" uid="{194041B7-4A42-49AD-9AB1-BFC997765D6F}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Microsoft\Office\16.0\Outlook\AutoDiscover" name="EnableOffice365ConfigService" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeExplicitO365Endpoint" status="ExcludeExplicitO365Endpoint" image="11" changed="2023-01-06 06:44:28" uid="{5F314DA6-E185-477E-985C-06B23414101E}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Policies\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeExplicitO365Endpoint" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeLastKnownGoodURL" status="ExcludeLastKnownGoodURL" image="11" changed="2023-01-06 06:44:52" uid="{4E4FA923-0695-44F2-A4C1-8026615BA571}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Policies\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeLastKnownGoodURL" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeHttpsRootDomain" status="ExcludeHttpsRootDomain" image="11" changed="2023-01-06 06:45:05" uid="{A9B1A99D-16F2-4421-BD93-B8850A6B62C1}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Policies\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeHttpsRootDomain" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeHttpsAutoDiscoverDomain" status="ExcludeHttpsAutoDiscoverDomain" image="11" changed="2023-01-06 06:45:31" uid="{85F10106-1B5D-49A6-8782-D69355A0719C}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Policies\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeHttpsAutoDiscoverDomain" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeHttpRedirect" status="ExcludeHttpRedirect" image="11" changed="2023-01-06 06:45:36" uid="{DD799D8D-A86C-4EB4-B0DB-D31A7E0B5E7D}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Policies\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeHttpRedirect" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeScpLookup" status="ExcludeScpLookup" image="11" changed="2023-01-06 06:45:42" uid="{DC5FA5D9-0ADC-4A87-9525-7A6D436D9957}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Policies\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeScpLookup" type="REG_DWORD" value="00000001"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="ExcludeSrvRecord" status="ExcludeSrvRecord" image="11" changed="2023-01-06 06:45:50" uid="{7232EDBC-B500-4BB7-BB54-87F674C5A5F5}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Policies\Microsoft\Office\16.0\Outlook\AutoDiscover" name="ExcludeSrvRecord" type="REG_DWORD" value="00000000"/></Registry>
            <Registry clsid="{9CD4B2F4-923D-47f5-A062-E897DD1DAD50}" name="EnableOffice365ConfigService" status="EnableOffice365ConfigService" image="11" changed="2023-01-06 06:45:57" uid="{E08FC552-3554-4909-84FE-8D04FF60F921}"><Properties action="R" displayDecimal="1" default="0" hive="HKEY_CURRENT_USER" key="Software\Policies\Microsoft\Office\16.0\Outlook\AutoDiscover" name="EnableOffice365ConfigService" type="REG_DWORD" value="00000001"/></Registry>
          </RegistrySettings>
          user.reg
          Windows Registry Editor Version 5.00
          [HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Outlook\AutoDiscover]
          "ExcludeExplicitO365Endpoint"=dword:00000001
          "ExcludeLastKnownGoodURL"=dword:00000001
          "ExcludeHttpsRootDomain"=dword:00000001
          "ExcludeHttpsAutoDiscoverDomain"=dword:00000001
          "ExcludeHttpRedirect"=dword:00000001
          "ExcludeScpLookup"=dword:00000001
          "ExcludeSrvRecord"=dword:00000000
          "EnableOffice365ConfigService"=dword:00000000
          [HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\16.0\Outlook\AutoDiscover]
          I don't like anything other than DNS Records 😛
          3 months later
          Get Folder-Permissions a bit quicker than before...
          exmdb_get_permissions_hr() {
            local OWNER FID PFLDS FOLDER EXMDB SQLQUERY RET
            if [[ "$#" -ne 1 ]]; then
              echo "Usage: ${FUNCNAME[0]} username@domain.tld"
              return 1
            fi
            _grom_users="${_grom_users:=$(grommunio-admin user query username |sed 1d)}"
            # Check for correct Username
            if [[ "$_grom_users" =~ $1 ]]; then
              OWNER="${1}"
              EXMDB="$(grommunio-admin user query maildir --filter username="$OWNER")/exmdb/exchange.sqlite3"
              # grommunio-admin taginfo 805371935
              # 0x3001001f (805371935): DISPLAYNAME, type WSTRING
              SQLQUERY="
          -- THIS IS A COMMENT!
          -- SELECT DISTINCT(printf('0x%x', p.folder_id)) as hexfid, f1.propval FROM permissions p
          -- INNER JOIN folder_properties f1 on f1.folder_id = p.folder_id and f1.proptag = 805371935
          SELECT DISTINCT(printf('0x%x', p.folder_id)) as hexfid FROM permissions p
          WHERE p.username != 'default';
                # True if FILE exists and is readable.
                if [ -r "$EXMDB" ]; then
                  PFLDS="$(echo "$SQLQUERY" |sqlite3 --readonly --noheader "$EXMDB")"
                  if [ "${#PFLDS}" -eq 0 ]; then
                    echo "No special permissions in MBX: $OWNER"
                    return 0
                  fi
                  grommunio-admin exmdb "$OWNER" folder list -r | while read -r FOLDER; do
                    # Leading '\' in front of grep to make sure no aliases are used.
                    FID="$(echo "$FOLDER" |\grep -Po '0x(?<=\ \(0x).*(?=\)$)')"
                    echo -e "\033[1m${FOLDER}\033[0m"
                    if [[ "$PFLDS" =~ $FID ]]; then
                      grommunio-admin exmdb "$OWNER" folder permissions "$FID"
                    fi
                  done
                fi
            fi
          complete -F _comp_grom_users exmdb_get_permissions_hr
          Because iterating over a thousand folders with grommunio-admin exmdb user@domain.tld permissions $FOLDERID takes bit too long if nothing is configured anyway..
          There are some folders which are not listed with grommunio-admin exmdb user@domain.tld folder list -r, so it might print the List in those cases.
          a month later
          crpb Automated version with Configs from RPMs and other sutff
          The script to build and configure traffic-status and brotli now removes all temporary dependencies to keep a small footprint on the Server.
          alien8.sh
          a year later
          /tmp as tmpfs on appliance
          ref: https://en.opensuse.org/openSUSE:Tmp_on_tmpfs
          BTRFS SYSTEM OLD
          btrfs subvolume delete -i $(btrfs subvolume list /  |awk '/@\/tmp/ {print $2}') /
          systemctl link /usr/share/systemd/tmp.mount
          rm -Rf /tmp
          reboot
          XFS SYSTEM CURRENT
          rm -Rf /tmp/*
          reboot
          crpb changed the title to scripting / snippets / notepad .
          only learn and optional delete with a minimum age of n days
          #!/bin/bash
          # vim:ts=2 sts=2 sw=2 et
          if ! [ -e /etc/gromox/spamrun.cfg ]; then
            cat << EOF > /etc/gromox/spamrun.cfg
          # Only scan messages which are older than n days.
          # Default: SPAMRUN_DAYS=7
          SPAMRUN_DAYS=7
          # To delete the message after the scan set to 'true'
          # Default: SPAMRUN_DELETE=false
          EOF
          fi
          # source config file
          if [ -r /etc/gromox/spamrun.cfg ]; then
            . /etc/gromox/spamrun.cfg
          fi
          if [ -z ${SPAMRUN_DAYS+x} ]; then
            SQLITE_QUERY='select message_id,mid_string from messages where parent_fid=0x17;'
          else
            SQLITE_QUERY="""
            SELECT m.message_id,m.mid_string
            FROM messages m
            INNER JOIN message_properties mp1
            ON mp1.message_id = m.message_id
            AND mp1.proptag = 235274304
            AND (mp1.propval/10000000-11644473600) < unixepoch('now','-$SPAMRUN_DAYS days')
            WHERE m.parent_fid = 0x17;
          fi
          DO_DEL="${SPAMRUN_DELETE:-"false"}"
          # add "-d" to delete junk emails after they have been learned
          if [ "$1" = "-d" ]
          then
            DO_DEL=true
          fi
          MYSQL_CFG="/etc/gromox/mysql_adaptor.cfg"
          if [ ! -e "${MYSQL_CFG}" ] ; then
            echo "MySQL configuration not found. (${MYSQL_CFG})"
            exit 1
          fi
          MYSQL_PARAMS="--skip-column-names --skip-line-numbers"
          MYSQL_USERNAME=$(sed -ne 's/mysql_username\s*=\s*\(.*\)\s*/-u\1/pI' ${MYSQL_CFG})
          MYSQL_PASSWORD=$(sed -ne 's/mysql_password\s*=\s*\(.*\)\s*/-p\1/pI' ${MYSQL_CFG})
          MYSQL_DBNAME=$(sed -ne 's/mysql_dbname\s*=\s*\(.*\)\s*/\1/pI' ${MYSQL_CFG})
          MYSQL_HOST=$(sed -ne 's/mysql_host\s*=\s*\(.*\)\s*/-h\1/pI' ${MYSQL_CFG})
          MYSQL_QUERY="SELECT username,maildir from users where id <> 0 and maildir <> \"\";"
          MYSQL_CMD=("mysql" "${MYSQL_PARAMS}" "${MYSQL_USERNAME:=-uroot}" "${MYSQL_PASSWORD:=}" "${MYSQL_HOST:=-hlocalhost}" "${MYSQL_DBNAME:=grommunio}")
          # shellcheck disable=SC2068
          if ${MYSQL_CMD[@]}<<<"exit"&>/dev/null; then
            echo "${MYSQL_QUERY}" | ${MYSQL_CMD[@]} | while read -r USERNAME MAILDIR ; do
            sqlite3 -readonly -tabs -noheader "${MAILDIR}/exmdb/exchange.sqlite3" "$SQLITE_QUERY" |
              while read -r MESSAGEID MIDSTRING; do
                echo "Learning spam for user ${USERNAME}" | systemd-cat -t grommunio-spam-run
                MSGFILE="$MAILDIR/eml/$MIDSTRING"
                if [[ ! -f "$MSGFILE" ]]; then
                  gromox-exm2eml -u "${USERNAME}" "${MESSAGEID}" 2>/dev/null | rspamc learn_spam | systemd-cat -t grommunio-spam-run
                else
                  rspamc learn_spam --header 'Learn-Type: bulk' "$MSGFILE" | systemd-cat -t grommunio-spam-run
                fi
                if [ ${DO_DEL} == "true" ]; then
                  /usr/sbin/gromox-mbop -u "${USERNAME}" delmsg -f 0x17 "${MESSAGEID}" | systemd-cat -t grommunio-spam-run
                fi
              done
              rm -f "${SPAMLIST}"
            done
          else
            echo "MySQL-Connection couldn't be established, please check your configuration." | systemd-cat -t grommunio-spam-run -p err
          fi
          appliance - xfs - dedicated /var/lib/gromox
          DISK=/dev/sdb
          parted -s $DISK mklabel gpt
          parted -s $DISK mkpart primary 0GB 100%
          pvcreate ${DISK}1
          vgcreate gromox ${DISK}1
          # use only 80% so we can make use of lvm snapshots for backups
          lvcreate gromox -n maildir -l80%VG
          # enable bigtime=1 to remove silly messages about 2038
          mkfs.xfs -m bigtime=1 /dev/gromox/maildir
          #lsblk -f /dev/gromox/maildir --output UUID --noheadings
          echo "UUID=$(lsblk -f /dev/gromox/maildir --noheadings --output UUID) /var/lib/gromox xfs defaults 0 0" |tee -a /etc/fstab
          mv /var/lib/gromox{,.bak}
          mkdir /var/lib/gromox
          mount /var/lib/gromox
          #cp -a /var/lib/gromox.bak/* /var/lib/gromox/
          rsync -av /var/lib/gromox.bak/ /var/lib/gromox
          find /var/lib/gromox -ls
          #chown gromox:gromox /var/lib/gromox
          #chmod 770 /var/lib/gromox
          rm -Rf /var/lib/gromox.bak
          LVM Snapshot for backups - example
          ##  STOP SERVICES TO CLEANUP midb's
          /usr/bin/systemctl stop gromox-midb.service gromox-imap.service gromox-pop3.service
          # DO SOME CLEANUP ON THE MAILBOXES
          for d in /var/lib/gromox/user/*/*; do
            /usr/sbin/gromox-mbop -d $d vacuum;
            /usr/sbin/gromox-mbop -d $d purge-datafiles;
          done
          ## CREATE LVM SNAPSHOT
          /sbin/lvcreate -l10%FREE --snapshot --name s_maildir /dev/gromox/maildir
              Logical volume "s_maildir" created.
          ## START SERVICES AGAIN (we have a snapshot!)
          /usr/bin/systemctl start gromox-midb.service gromox-imap.service gromox-pop3.service
          ## SHOW THAT WE HAVE A SNAP
          /sbin/lvs
            LV        VG        Attr       LSize  Pool Origin  Data%  Meta%  Move Log Cpy%Sync Convert
            LVRoot    grommunio -wi-ao---- 19.68g
            maildir   gromox    owi-aos--- 40.00g
            s_maildir gromox    swi-a-s---  1.00g      maildir 0.00
          ## TEMPORARY MOUNT POINT
          SNAP=$(mktemp --suffix=lvmsnap --directory)
          ## MOUNT XFS ( we need -o nouuid as xfs doesn't like duplicates of UUIDs )
          /usr/bin/mount -o nouuid /dev/gromox/s_maildir $SNAP
          ## SHOW THE CONTENTS
          /usr/bin/find $SNAP -ls
                128      0 drwxrwx---   5 gromox   gromox         45 Apr  1 16:41 /tmp/tmp.xa5jeBj8Rylvmsnap
                131      0 drwxrwx---   2 gromox   gromox          6 Mar 30 20:50 /tmp/tmp.xa5jeBj8Rylvmsnap/domain
           33554560      0 drwxrwx---   6 gromox   gromox         56 Mar 30 20:50 /tmp/tmp.xa5jeBj8Rylvmsnap/queue
           67149888      0 drwxrwx---   2 gromox   gromox          6 Mar 30 20:50 /tmp/tmp.xa5jeBj8Rylvmsnap/queue/mess
          100663424      0 drwxrwx---   2 gromox   gromox          6 Mar 30 20:50 /tmp/tmp.xa5jeBj8Rylvmsnap/queue/save
                132      0 drwxrwx---   2 gromox   gromox          6 Mar 30 20:50 /tmp/tmp.xa5jeBj8Rylvmsnap/queue/timer
           33554561      0 drwxrwx---   2 gromox   gromox          6 Mar 30 20:50 /tmp/tmp.xa5jeBj8Rylvmsnap/queue/cache
           67149889      0 drwxrwx---   2 gromox   gromox          6 Mar 30 20:50 /tmp/tmp.xa5jeBj8Rylvmsnap/user
          ## RUN BACKUP / RSYNC / WHATEVER
          ## AND AFTER WE ARE FINISHED
          /usr/bin/umount $SNAP
          /sbin/lvremove /dev/gromox/s_maildir --yes
          APT Pinning Supported/Community/Devel
          Whomever might need it. Now you can 🙂
          v=supported will also be available in a few days.
          % apt policy
          Package files:
           100 /var/lib/dpkg/status
               release a=now
            50 https://download.grommunio.com/devel/Debian_12 Debian_12/main amd64 Packages
               release v=devel,o=grommunio,n=Debian_12,l=grommunio,c=main,b=amd64
               origin download.grommunio.com
           450 https://download.grommunio.com/community/Debian_12 Debian_12/main amd64 Packages
               release v=community,o=grommunio,n=Debian_12,l=grommunio,c=main,b=amd64
           500 https://download.grommunio.com/supported/Debian_12 Debian_12/main amd64 Packages
               release o=grommunio,n=Debian_12,l=grommunio,c=main,b=amd64
           500 http://ftp2.de.debian.org/debian bookworm-updates/main amd64 Packages
               release v=12-updates,o=Debian,a=stable-updates,n=bookworm-updates,l=Debian,c=main,b=amd64
               origin ftp2.de.debian.org
           500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
               release v=12,o=Debian,a=stable-security,n=bookworm-security,l=Debian-Security,c=main,b=amd64
               origin security.debian.org
           500 http://ftp2.de.debian.org/debian bookworm/main amd64 Packages
               release v=12.5,o=Debian,a=stable,n=bookworm,l=Debian,c=main,b=amd64
          Pinned packages:
               libapache2-mod-php -> 2:8.2+93 with priority -1
               apache2-bin -> 2.4.57-2 with priority -1
               apache2 -> 2.4.57-2 with priority -1
          % cat /etc/apt/preferences.d/80-grommunio
          Package: *
          Pin: release o=grommunio, v=devel
          Pin-Priority: 50
          Package: *
          Pin: release o=grommunio, v=community
          Pin-Priority: 450
          % cat /etc/apt/sources.list.d/grommunio.sources
          # Supported
          Types: deb
          URIs: https://download.grommunio.com/supported/Debian_12/
          Suites: Debian_12
          Components: main
          Enabled: yes
          Signed-By: /usr/share/keyrings/download.grommunio.com.gpg
          Signed-By:
           -----BEGIN PGP PUBLIC KEY BLOCK-----
           mQINBGKBYeIBEADcZy8/VYP6z1kzZK2pjdun5H8D5ivstS8e/yHwhuXH/zIiv0v/
           RBZx14GYfK5/GyVyv1GtOvm6w1Cfw1f6LPZx6tCH8la+jyup6TDW8M+wvzL3dQxI
           t2gSVWkMy5t57pHF5X+V4w/h4nooPYCMRD35yOqUBefOhhmDhmz5XY2vth4WbXtk
           0n01xhrtTfgAx0e3mjQbB1n5ERU7plM7b22ETO6a6PAnQ25YNlEtyDoIkKE08gU+
           oZEH4hPXG4diuUz465ndDx1gw9eKhjZs10K8cJRm9504kt2KQDtbbxfRZC0xGq2D
           QpSQ47TSRqxdEtRIXIICcyLKo1OX0Fxr27lsi0W9Bo57C0ekmeJicK/K56Cx4vhH
           fNO0gQqjKHF2+2VN/NkWKjfqE577jnBEHASsIBeONV62dxZANeHOEUzDdXNCkLqV
           YhWaDUezsrc48gx6z4Qu82Z5Vh9Po49PyrM+pZRPrTNrj8DyJwnuFCFHLDy5ICiw
           wn9lZLQbshbEY0fUI9Z/0glEwkbuZupoU0QEHqFwD++n0u2RQBJrUEw36Aw/OPZk
           6KKlzYLoB0Fj9So4xCNNG67HaFiIfY0yRPDWfIFHF+UifpEvnaFQPWYIlZaD3akT
           GZNn72Gu9Fd53QX969AX6fB9NW0ZiN4KLMHQH0Osp+ZyYoJFhe7iS6Wz0QARAQAB
           tDVncm9tbXVuaW8gUmVwb3NpdG9yeSBTaWduaW5nIEtleSA8aW5mb0Bncm9tbXVu
           aW8uY29tPokCUwQTAQoAPRYhBIexso4eH2cheYzRzfRI3psb4jHZBQJigWHiAhsD
           BQkJZgGABAsJCAcFFQoJCAsFFgIDAQACHgECF4AACgkQ9EjemxviMdnIdA//fDnC
           BrtAmawZS1RijrHLGN56DURY1j5HBg0JRjfdMPkW66d+d41qj4zOa4UdNEG2+xWV
           oALY7LJ+nx/+RiPYt1KzX0Q4iS0HL9OJOT21JUQab9ovAC3y7NJ10UW3tifYT9Tq
           Q0FaDcha1/hvGIhoRDgJlC5gjYinXjxS48o+MUIqwgaipGmiLnlktTq8l75lLpC0
           6qqBk2A6Sb5syKxQ4mUEjvZZxOxXyB6ebfnbHoHgSDGN+fgYzfoIt5/dF26ZcYwf
           mMsl4GEGbcVed/XfsTUtLVTDXFeDOuHsHmdpmLgrCCY369OZOoBtPhG83BLzRIgS
           F5+bWl/WM0AGtjEhMvSGG51evdHKK8LQ6sYQ6iIwvRxsrj9IE325cl4AY0fcvzvN
           eEMe41bDLrcyC88yAEAJJ3bHEik3St8KlvBmyOYwUwbs+uptOFTxLIa6/5qHJIU/
           HaUlj248Jf1ujHzgWbfdlvdVoeYpEdAgPFYCiiZE+Nuh8iV/FpFME2ahtTQ8NCu5
           xLeCom9fRM1bl9OvEhgzJNItag5Ew3acuBEb9IogZ2TJOJvF8rlwswp1RAQnJuI9
           /lKyKG+7xGf3cDryeyxEHKYpG30ekR6AtPID5Xte2L89lMkVW1h1GbkhRoJP/dRg
           L33OJ76zma2qy9rYA6xeYC/9bz8rFi1SDcqoHn+5Ag0EYoFh4gEQAPOUfEvK8bC+
           vckBsZ9ASG+RbA7w0rYfJsVDHrjM9L0KfgcFOtZgaQoClreDl5irmno/RtEsT23V
           XIvDw3Ih1pe/aAQFfZYb0896ZpAihNwEyjLucfUee8gU4qwLzFDpM84zsMlHtvOG
           ct3iw63FQp+hPqKfa/S8Z6PiQR/RiXgowx3vbIgzd9ULz4BY5+p7d2I3m6mKk3k8
           74B3Z4ovV+7Z7cwkgb+iVEJDXIcQlbbzQ8kE/kHa6nXMpR0ycXReqh2W8wmejMd3
           brG3JXAWLNxLLVI3NJcCLB3cTpbzYHKQbvpFiV6pldIpKypmcAsiIJT1DCRd3UkH
           xXMeMyZpan/iYdCNsXIKxbgxe7jf8GYB/0AXyb9nSsAoHX/7II2/VbZtGkeSUBiI
           Jm+bldFI+l3UkDB8RneNoHL6j/TATBe6L9AuKNsY6GVeSjS5xE6PIryHP64Ow5Qg
           1nxn0eNKG9vTNFRTPwJxySrVgx+t8RdaPB7E8xO/ru14Kt4ZtfYrh8ziBSTbPQQ5
           UrJGSooUk9hxj6US/we+D1LS/mMV+gCOnA/JuJW5UjcXloQYFuLyxStkjwSmrO77
           MiIob5m0JbFcNUmoPX21loepQt7CkjOwiHVqKrtLoMtYVjNd10RXVDrRylDUvuHU
           l3/GGQrWKj9LRcsgWY52u8MsGWPc3g0PABEBAAGJAjwEGAEKACYWIQSHsbKOHh9n
           IXmM0c30SN6bG+Ix2QUCYoFh4gIbDAUJCWYBgAAKCRD0SN6bG+Ix2bhtEACjsQnT
           wQMmUhh/DZInZOY2UWTZROm9+QbB9PXVi9x99KOtI0hSNTuEGcXNtfGEoj58MQFo
           gM0MwZ8Na2jQBJCX44lzt1fBDe3zb/nZEf3iu5H8bXVtJ+h7NxgP2pVk3Fb56hef
           fZiaqCflk/+g3FN2z6XElhwDS75Ek3rwy/a/LvLfKN9Ct6IAN+L8HBuaWeNmIrax
           nxaw+D9dPAUaWkJRG9DOcLxfh8qpewACZpqJ8JlcKLMK0KQU7IbeFz8IGwJLX6/0
           KypJq0iGQeJpHG4ANRR3WlXI0uI3AWn0qysF0ydZVdaehEqsJ2glInm2LYsevICh
           HvY/OKXRq236dD6GY07pSzjCuuR5L8KHbwzUSA1+jyZj3Kw+7oSiiFoEhbZMgOxs
           rUV9nLNPhHgyJNOQEKZSRK4IG6aylVm+om1C3mbrIk4w1Qj66unfeAaahRqq7FG3
           jvqkgm8u9BmiIWnrQyrEAlXEIpyO29IbSP6pCsBT7bfN+CyLLg5r4ivoFXq6P6uy
           LaP8TGqrXl8t1CLgHfXBfJ3J08newiDFN8KYdi5EY45jE/c3/930l8frICqG6Gmk
           XK8SB4W7zDLympnRuW5cKexUzKMtjENgk8QLfUSWL4CBm6syq6vh2z1xLdaGhZ54
           mGJfShvIgpqehgKMDoUzZkpIov34ef7O6RxVVA==
           =D9oD
           -----END PGP PUBLIC KEY BLOCK-----
          # Community
          Types: deb
          URIs: https://download.grommunio.com/community/Debian_12/
          Suites: Debian_12
          Components: main
          Enabled: yes
          #Signed-By: /usr/share/keyrings/download.grommunio.com.gpg
          Signed-By:
           =D9oD
          # Devel
          Types: deb
          URIs: https://download.grommunio.com/devel/Debian_12/
          Suites: Debian_12
          Components: main
          Enabled: yes
          #Signed-By: /etc/apt/keyrings/download.grommunio.com.gpg
          Signed-By:
           =D9oD
          a month later
          Activate ZRAM Swap
          *vroom* *vroom*
          OpenSuSe
          zypper in -y zram-generator
          mkdir -p /etc/systemd/zram-generator.conf.d
          printf '[zram0]\nzram-size = int(ram)\n' >> /etc/systemd/zram-generator.conf.d/0.conf
          Debian
          apt-get install -y systemd-zram-generator
          echo 'zram-size = int(ram)' |tee -a /etc/systemd/zram-generator.conf
          This will end up with 100% zramswap of the original ramsize.
          That isn't the double of ram just out of the blue tho :-).
          https://www.kernel.org/doc/html/next/admin-guide/blockdev/zram.html
          a month later
          Passwordless IMAP for archive purposes
          No more relying on users to update their passwords for external mail archiving over imap or worse storing their passwords /o\.
          References:
          https://community.grommunio.com/d/349-geloschte-objekte-wiederherstellen/9
          https://community.grommunio.com/d/836-seperate-authmgrcfg/6
          Upstream: https://github.com/crpb/grommunio/blob/main/tools/enable-pwless-imapd
          Changed a few things, look at the upstream url..
          Caveats: as i use an additional firewall-cmd zone the rules for like 443,8443,.. will not work and you might have to add them if you need or you might change the script to use the public zone.
