• Solved
  • Outlook sync problems (a lot of them)
With the new Appliance release and the upgrade of gromox 2.40 we have also sync problems on outlook in cache mode if a new mail is created and sent by Grommunio Web App then the sent folder yould not be synced anymore - also if we delete the mail from sent folder - sent folder gets synced again but then the trash folder stops sysncing as long as the deleted "sent" mail is in the trash
so it seems there is a problem with mails created in Grommunio Web
rg
Christian
    Fine,
    there is someone else who posts the same problem as I.
    I hope anyone from the grommunio team reads this and resolves this problem.
    I am sure when this problem is solved, the other sync problems are solved too.
    gromox-2.40.8.9ee79e2-lp156.5.1.x86_64 was released last night, try this update.
      nothing changed same problem persists
      We have identified some potential problem here.
      To support our investigation, we would kindly request you to answer the following questions:
      • Have you migrated you data into grommunio (we suspect yes)?
      • If so, from where did you migrate from and how/what tool have you used for the migration?
      • From when (date, or if you can even recall from which gromox-version) was the store created (the better the estimate, the better to check for us)?
      Thanks.
        mwilliams
        No there was no migration - installed plain new appliance - empty mailbox - create mail in outlook (cached mode) - gets synced (is available in Grommunio-Webmail)
        create mail in Grommunio-Webmail - sync errors in outlook cached mode and no new mail created from Grommunio-Web gets synced -
        switch outlook to online mode - all mails available
        rg
        Christian
          Its exactly the same for me.
          New installed yesterday
          And as described earlier.
          When Outlook is running, every thing I do in the WEB interface results in Sync errors.
          @mwilliams:
          Two setups (with each some outlook cached mode sync problems):
          Setup one:
          • With migration from kopano using grommunio's kopano migration script
          • Mailbox created with gromox 2.16
          Setup two:
          • New mailboxes, no migration
          • Mailboxe created with gromox 2.16 too
          Both setups encounter the same sync problems.
          Can elaborate if needed.
          Now I see this issue in Calendar and Sent Items (Gesendete Elemente).
          I deled the .OST file and Sent Items contains only 3 mails, the 4. mail was created with G-Web and this mail and all older mails are not synced into my caching mailbox.
          externa1
          same behavior with Gromox 2.41.0 update today
          rg
          Christian
          I am seeing the same issue also at this point I can not even use the web mail interface.
          I have multiple computers with outlook same account all set to offline cache and if I only use them the sync works fine.
          I can view the emails on the web and see all emails in the folders I changed via outlook.
          Were things break is the moment I make any changes even deleting an email the sync messages start flowing.
          Where I first noticed it is in sent items I had did on the web were not in my outlook.
          Another thing that happens is once the sync error occurs even is you delete the account or clear the cache for the offline folder outlook will not sync any of the mail into the folder only new items even if they are all on the server.
          It seems like all the folders except the inbox seen to sync.
          I've noticed another pattern, perhaps not correlated to the webapp/offline sync issue.
          Most of the outlook offline cache sync problems I encounter are on accounts that open more than one mailbox (user mailbox + another user mailbox), or that are opened by multiple outlook clients.
          Most of the sync problems happen when a user moves emails between folders.
          Hope this helps the team to find the trigger the issue more easily.
          gromox 2.41.7 contains the fix. But the fix du not work as expected.
            WalterH Walter in what way does the gromox 2.41.7 fix for this sync issue not work as expected. Don't want to apply it and open more problems
            EDIT: It appears that this 'fix' was published before I updated my Appliance instances yesterday and I already have it installed and it certainly has not fixed the sync issues I am experiencing.
            No the problem is still the same
            so no webmail usage possible when using outlook sync mode too
            rg
            Christian
            This was an issue with imported items from Kopano.
