Hello!
Facing problems again after another update and i'm not sure where to start.
Actually: everything looks to be working fine (sync and webclient) but i have no "console":
If i try to reinstall console it comes back but says nginx is not running even if everything looks to be working.
zypper remove grommunio-cui; rm -rf /usr/libexec/grommunio-cui; zypper install -y grommunio-cui; systemctl restart grommunio-cui@tty1.service
localhost:~ # systemctl restart nginx
localhost:~ #
If i reboot i'm back to the "no console" status with a working webclient
If i try to update, i'll go back to the "no console" status but lose webclient access aswell.
The following 12 package updates will NOT be installed:
dracut-kiwi-lib dracut-kiwi-live dracut-kiwi-oem-dump dracut-kiwi-oem-repart
kiwi-systemdeps-bootloaders kiwi-systemdeps-core kiwi-systemdeps-disk-images
kiwi-systemdeps-filesystems kiwi-systemdeps-iso-media kiwi-tools
system-user-grodav system-user-grosync
The following 24 packages are going to be upgraded:
grommunio-admin-api grommunio-admin-web grommunio-antispam grommunio-dav
grommunio-release grommunio-setup grommunio-sync gromox gromox-debuginfo
gromox-debugsource libHX32 libexmdbpp0 libfreebl3 libpff1 libsoftokn3
libvmime-suse5 mapi-header-php mozilla-nss mozilla-nss-certs
openSUSE-build-key python3-pyexmdb system-user-grommunio tcl timezone
The following 2 NEW packages are going to be installed:
libolecf1 sqlite3-tcl
The following 3 packages are going to be REMOVED:
system-user-grodav system-user-grosync system-user-groweb
24 packages to upgrade, 2 new, 3 to remove.
Overall download size: 28.1 MiB. Already cached: 0 B. After the operation,
additional 825.0 KiB will be used.
Continue? [y/n/v/...? shows all options] (y):
if i reinstall cui again, it says again "nginx not running" but nginx is actually started:
nginx.service loaded active running The nginx HTTP and reverse proxy server
If i try to update again i get errors from repository:
localhost:~ # zypper up
Loading repository data...
Warning: Repository 'debug-update' appears to be outdated. Consider using a different mirror or server.
Warning: Repository 'update' appears to be outdated. Consider using a different mirror or server.
Reading installed packages...
The following 10 package updates will NOT be installed:
dracut-kiwi-lib dracut-kiwi-live dracut-kiwi-oem-dump dracut-kiwi-oem-repart kiwi-systemdeps-bootloaders
kiwi-systemdeps-core kiwi-systemdeps-disk-images kiwi-systemdeps-filesystems kiwi-systemdeps-iso-media kiwi-tools
Nothing to do.
Any help welcome!
Regards
